Question about Whirlpool Cabrio WTW5600XW Top Load Washer
How to access timer on inglis washing machine
I have an Inglis washing m/c mod. #IL42000. It stops cycle (varies what position) then suddenly starts up again (time varies) What is wrong or needs to be replaced. I changed the tmer approx. 3 months
Something is possibly overheating and cutting out? Or due to recent timer change it may be wire connection that's come loose or a wire has got trapped underneath something and cut through the wire causing an intermittent fault.
Jan 02, 2015 | Washing Machines
My Kitchenaid Superba washing machine won't advance to the next cycle. For instance, it will stay on the wash cycle until you push the dial in and manually move it forward to the next cycle.
ck ing the model # it doesn't work but a washer that the timer will not adv . its just a timer failure . replace timer as it is bad .. you will need a correct mod # of the unit to pur timer .. hope this will help **** ..
Dec 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Inglis washing machine won't spin
Turn the timer indicator to the asterisk * start it up. It should agitate without no water in it. If it don't agitate you have a bad coupling part number 285753 whirlpool. Google it.
Dec 18, 2008 | Washing Machines
INGLIS WASHER DOES NOT RUN
try to advance your timer just a little bit to see if it will kick through to the next cycle.
Aug 13, 2008 | Washing Machines
Inglis Superb 2 washer,
Inglis cloths washer Model L038001 will not drain or agitate
Jun 25, 2008 | Washing Machines
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Cabrio WTW5600XW Top Load Washer Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
