Question about Master Plumber Sta Rite Pentair 540114 1/2 Hp Thermoplastic And Stainless Steel Pump
My pump will only nwork for several seconds then recycles
Why does my truck start up and run for about 10 seconds before it dies? I
It should at least run for several seconds after you turn the key on. It MAY run longer, but it SHOULD run for several seconds. If fuel demand goes down (engine not burning much fuel), the pump may not run after that.
Aug 02, 2014 | Ford F-150 Cars & Trucks
What are recycled plastic Adirondack chairs made from?
Most companies that make recycled plastic Adirondack chairs are using old water bottles and milk containers. They can be made from up to 90% recycled plastic and are said to last several years. In my opinion, this is an option worth looking into. They will probably be quite inexpensive too.
Aug 26, 2012 | Adams Garden
Not charging . not nworking battery dead?
mcdevito75 here, If the battery is 2 years old, it could be un--able to accept a charge. Double check instalation into the charger, make sure charger itself is plugged into outlet. If so, visit a small watch repair shop in your area for battery change.
Jun 27, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
My spider 3 30w needs to be turned on then off and then on again to work. After that, works perfect...?
This might seem silly, but are you sure you have waited after turning the unit on long enough?
Some of these may take several seconds to balance the amps and any effects modules. Turning off and on again would probably not recycle the power on conditions if done fairly quickly. I have units that take 10 seconds before they become active.
Mar 11, 2010 | Music
My renault clio dipped beam light are not nworking
itll be the light arm there allways going yes the swich has gon thanks ben
Nov 16, 2009 | 2006 Renault Le Car
I have toro 6.5 super/recycler that stalls out after about 5-10 minutes after it starts up then it will not start for about 30 mins. i've changed the spark plug and cleaned the filter
Dont know if this is the same problem but it may help. I've recently bought a used Toro 6.5 recycler and have cut the lawn 3 times with it. This third time it began to stall out on me. If I hit the primer button several times it would start up but then die again. I thought I'd have to pull the carb and clean it, ut after looking at a few problem listings online I realized it was probably just some trash in the needle valve. I managed to get it running again by first pushing the primer pump 3-5 times, then pulling the cord to crank it, then while holding the contact bar in place with one hand to keep it running I reached down and pumped the prime button a few times before it cut out again- after one or two tries it apparently flushed the trash out and it ran fine again. Had the same problem later and fixed it the exact same way, then went on to finish the yard.
Sep 08, 2009 | Garden
Headphone doesnot nworking
ok all the sound card comes with a software , n every software by default is assigned to speaker mode , open the audio software n then re plug the headfone it will show multiple uption such as line in , headfone,speaker etc ,, select the head fone option n apply the changes ,, it should work !!!
Jun 25, 2009 | Computers & Internet
95 chrysler lebaron
You're fuel pump relay may be bad on it. It may be shutting the pump off the second you go to start the car. I've seen alot of problems with these.
Jul 13, 2008 | 1995 Chrysler LeBaron
Sound Fades, then TV shuts off then continues to recycle on & off
Sometims several capacitors start going bad giving you the audio problem, but I don't remember the set turning itself off. That could be a secondary problem around the flyback transformer which may have a bad solder connection. I would check that first. Otherwise, I would be tempted to go with HDTV.
May 29, 2007 | RCA F36685 36" TV
Master Plumber Sta Rite Pentair 540114 1/2 Hp Thermoplastic And Stainless Steel Pump Logo
24 people viewed this question
Top Master Plumber Plumbing Experts
Tom Chichester
Paul Carew
Are you a Master Plumber Plumbing Expert? Answer questions, earn points and help others
