Question about Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator
Fisher&paykel ice maker got loose
Fisher&paykel ice maker got loose. What to do?
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge is less than
Try the video on the F&&P icemaker it will walk you thru diagnosing the problem. www.appliancehelponline.com/servicemanual.html
dj_relly999
  • 4070 Answers
SOURCE: I have a Fisher & Paykel Refrigerator. The
Hi! The refrigerator has dual valve with two coils at the back and the ice side may have gone bad thats why it doesnt make ice. YOu will have to have it replaced to get your fridge back to its normal working condition. Hope this helps and have a good one!
Posted on Aug 03, 2010
imufo2
  • 3773 Answers
SOURCE: How do i manually force a dump on a fisher and
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 19, 2011
imufo2
  • 3773 Answers
SOURCE: RF201ADUX Fisher & Paykel ice
NOTE: This
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Posted on Sep 11, 2011
The sensor in the freezer has come loose
It belongs under the Ice tray to the Ice maker. Without it the unit can not detect temperature of the ice tray to cycle or function as needed.
I hope this helps.
Mar 23, 2013 | Fisher Paykel E522BRXFDU Fisher & Paykel...
Fisher and Paykel RF201ADUX Refrigerator - error code F30 F31
I found loose wires under the top right hinge, where you will find a small connector block. Put the loose wires back in and hey preso the lights were back on, the water and ice defenses worked and the fault code was cleared
Mar 19, 2012 | Fisher and Paykel Refrigerators
My 3mth old e522brxu fisher and paykel ice maker has stopped working water is working fine you can manually force a dump and hear the cycle start to turn the tray but no water fills the tray can not hear a...
Hi, For the benefit of anyone doing a Google search for it (which is likely anyone with a Fisher and Paykel fridge w/icemaker) the broken wire is a notorious design flaw, and if you see it dangling from your ice tray - symptom is no ice being made -
You must remove the clip underneath the ice tray, and a little foam pad with it. There you will see the broken wire attached to a little black sensor. It's a little fiddly to do in place, but after unplugging the fridge (unless you like a good electric jolt) you need to splice the wire and reattach it. Your ice maker should resume working as intended.
Hope that helped.
Good luck.
May 26, 2011 | Fisher and Paykel E522BRXU Fisher & Paykel...
I have a Fisher & Paykel Refrigerator. The ice cube maker has stopped working and the 'force cycle' does not make the ice cube tray 'flip'. Any ideas?
Aug 03, 2010 | Fisher and Paykel Refrigerators
I cleaned out ice bin and now ice will not make on fisher paykel
did you turn the oce maker back on also check that when you pulled the bin out you did not pull the powr plug out of the side of the freezer just enough it don't work
Apr 22, 2010 | Refrigerators
Fisher & paykel refrigerator n325t freezing up
how long it takes to form the ice in a frost free (fisher & Paykle) refregerator ?
Feb 25, 2010 | Fisher Refrigerators
No ice
My ice maker makes about enough to fill 2" in bottom of tray then quits making ice, whats the problem I just got it two days ago
Jul 20, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Logo
23 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
