Hi!
If the buttons on your TI-83 Plus calculator are not working and a RAM reset does not resolve the issue, you may need to try a few other steps to diagnose and fix the problem:
- Check for corrosion or debris: Carefully remove the battery cover and batteries from the calculator. Inspect the battery contacts for any corrosion or debris. If you see any, clean the contacts with a soft cloth or a cotton swab dipped in rubbing alcohol. Be careful not to bend or damage the contacts.
- Check the keyboard: Inspect the keyboard for any physical damage or signs of wear. If you notice any damaged keys, you may need to replace the keyboard.
- Check the connector: If your calculator has an I/O port, try connecting it to a computer using a TI-Graph Link cable. If the calculator can communicate with the computer, then the issue is likely with the keyboard. If the calculator cannot communicate with the computer, the issue may be with the connector or the logic board.
- Contact TI Support: If the above steps do not resolve the issue, contact Texas Instruments customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend a repair or replacement for your calculator.
Note that opening the calculator to attempt repairs can be risky and may void your warranty, so it's recommended that you contact TI Support before attempting any repairs yourself.
Hope these steps can help you further.
Regards
