Denon dra 425r
Receiver shows no sign of power when plugged in and turned on. tired different known working power outlets. opened up the box and looked for a fuse or reset. did not see anything resembling a fuse or reset. sympom is no indication of power when turned on, and no indication of standby. does this receiver have a reset?
SOURCE: denon dra 1025ra seems to
Unplug receiver from AC outlet, and plug back in. The power reset should clear up the problem.
Posted on Jul 09, 2008
  • 7 Answers
SOURCE: MY DENON DRA-435 A RECEIVER
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Posted on Jul 23, 2008
  • 163 Answers
SOURCE: Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Posted on Apr 09, 2009
SOURCE: Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Posted on Jan 06, 2010
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
No power how to solve
Check outlet for power by plugging in a known working device to the outlet. If it has power, replace the power cable of the receiver. IF that still does not work, the receiver's power supply is dead.
Jan 21, 2016 | Denon AVR-1906 Receiver
Denon dra 25 no power
John,
If you have a multi meter then unpug from mains supply.With meter
on "ohms" range check the following:-
Fuse F501 (and F502 if mult-voltage model)
yellow to white on mains transformer this should show some resistance.If you have a mult-voltage model check
brown to gray and orange to white. Both should show some resistance, if not your mains transformer has an open circuit primary winding.....
Mar 03, 2014 | Audio Players & Recorders
I have a denon dra-697ci power is plugged in but face does not have any lights nor does the power switch have any both fuses are okay any sugestions would be greatly appreciated
Most likely, you Denon has a condition known as DC Offset(meaning a damaged amplifier which requires a major repair) The other issue, may be a microprocessor IC, a computer within you Denon) that has had some issue, causing it to not power up. Try a Factory Reset first. The procedure is found in you owners manual under, Reset, Factory Reset, or Rest to original setting, as it came from the factory..If you need further assistance, please contact me at my my website at audioserviceclinic.com. Thank you.
Jan 14, 2014 | Denon DRA-697CI
Denon DRA-435R: First, the "switched" outlet on the received stopped delivering power. Now the receiver does not power on, neither using the front switch, nor the remote. The Unswitched outlet still...
from your description its should be the switch or a loss connection
if it doean not power on now it could be the fuse
if you can open the unit follow the power cord inside you should see a glass fuse look if its burn if its ok its better to take to service
Aug 23, 2010 | Audio Players & Recorders
My receiver is making a static through my speakers even when the volume is turned all the way down
Check the electric outlet to make sure the polarity isn't reversed, which can cause static. Also, check the outlets in the room to make sure they are all grounded which can also produce static. Also, certain cell phones operating a different frequencies can produce a static.
Feb 25, 2010 | Denon DRA-275R
Apr 05, 2009 | Denon AVR-1906 Receiver
No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Dec 16, 2008 | Denon DRA-397
Denon dra 1025ra seems to be stuck in standby mode. How do I release standby to power up
May 18, 2008 | Denon Audio Players & Recorders
Remote lock on
This worked for me, but I'm sure tired of constantly searching for ways to fix the problems I encounter with my Denon DRA-397. When it works, it's great, but I don't have a degree in electrical engineering. Why can't they produce a user friendly trouble shooting guide?
Dec 14, 2007 | Denon DRA-397
44 people viewed this question
 Grubhead
Grubhead
