Question about Kenmore Ovens
F 13 code on fridigair oven - Kenmore Ovens
    Champion:
  • Kenmore Expert
  • 323 Answers
Posted on Feb 02, 2015
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
Outside glass on oven door exploded, can't find replacement code, as ID plate in oven unreadable. Model 65-867
I'm presuming that this is a Simpson Nova 65-867
By the look of all the data I can find, this is an Australian appliance. I'm in the UK, and I was presuming that you were in the US, but maybe you're in OZ.
If you are then you can go to
http://www.alliedappliance.com.au/about_allied_appliance.htm
And mail them with a request for help. They advertise loads of spare parts for your oven (but not glass in the listings I have seen). I imagine that they will be able to source what you need.
You can also make enquiries at The Big Warehouse.com, who also stock parts for your oven:
https://spares.bigwarehouse.com.au/contact_us.php?osCsid=3b1cdec4545fb97a677f2646a2b69530
Finally, go directly to Simpson. Contact information as follows:
Simpson appliances are stocked by a wide selection of quality electrical retailers throughout Australia.
To find your nearest outlet, please call our dedicated customer care number:
1300 363 640
For service related questions please call:
13 13 49
For information about spare parts call:
13 13 50
http://www.simpson.com.au/locator/search/retailer/
Worth noting that Simpson are part of the Electrolux group, so you may get help through a local Electrolux agent as well.
Jun 30, 2011 | Ovens
I HAVE A FRIDGIDAIRE STOVE AND OVEN MODEL #PLES389CC SER. #NF54421685 AND WHEN TURNING ON THE OVEN IT GIVES A F 13 CODE. WHAT COULD THAT BE?
Hi.
F13 means Bad EEPROM check, which in simple words means bad oven electronic control. The EEPROM is memory a chip mounted on the ERC board (oven control module). When the board detects that the data stored on the EEPROM is not valid you get this message.
Try disconnecting power from circuit breaker for ten minutes. If that does not work, try longer, leaving oven off for few hours. If that does not fix the problem, then the control module must be replaced.
Regards.
Ginko
May 31, 2011 | Frigidaire Ovens
How do you get a Fridigaire self-cleaning oven to self-clean?
most ovens have one button clean cycle . remove racks and close door push the clean button and it should lock the dooor and clean for 2.5 hr . then cool down befor you can get back in . if this does not work i will need a model # to help you more. mm
Aug 11, 2010 | Ovens
F 13
Had the same F13 code and beeping this morning; pulled the main breaker, waited 5 seconds, reset the breaker, and problem gone. Just had to reset the clock.
May 27, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Our Fridigaire range oven will not shut off. In
F1 is a bad oven control. (clock).
It must be replaced.
Unplug the range.
Remove the screws from the rear panel.
Remove the wires from the (clock).
Replace the EOC (clock) with a new control and bake me some cookies.
Feb 02, 2010 | Frigidaire Ovens
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Ovens Logo
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
