Question about GE Refrigerators
My GE Refrigerator GSS25KG the ice maker will fill up with water, it freezes, but will not drop the ice until I turn it off and back on again. What do I do?
Makes Ice, but will not drop it until I turn it off and back on again every hour.
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
  • 172 Answers
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
SOURCE: ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
SOURCE: Ice maker not dumping ice
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
My lfx25950 is not making ice
Most likely your water control valve is defective on the side for the ice maker. There are times that there is a slow leak and water freezes in the fill tube that fills the ice maker. That can be fixed by defrosting the fill tube with a hair dryer until the water valve is replaced. The next like ly problem would be a defective ice maker and sometimes there are problems getting parts for the LG brand. Do this, fill the ice maker with tap water turn on and let freeze. If it drops the ice the ne dual water control valve needs replaced. If it does nothing then the ice maker is the problem. I will be back soon with part numbers and where to find the parts you need. Try the test and if I am helpful please rate my solution, Thanks, Sea breeze
Sep 02, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker tube freezing up
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
