Question about Radio Communications
Why when i turn my car off radio keeps playing and wont switch off
    Problem Solver:
  • 20 Answers
If it is an aftermarket radio, it is wired incorrectly- One power wire goes to the battery, one needs to be switched by the ignition switch. If it is a factory radio, you will need to take it to the dealer or repair shop for diagnosis.
Posted on Oct 07, 2014
Radio wont turn on.
You have a power wire going to your on off switch you should also have a power going to a memory wire to keep your stations and clock intact.
Apr 21, 2013 | 1997 Toyota Camry
My 2002 impala radio heater blower and lights wont shut off after car car is off stays on till i disconnect the battery.
There may be a keep-alive relay or module that lets you play the radio after you turn the key off until you open the door.
This relay or module may have failed. Thats actually three different circuits but two are controlled by the key switch.
You may have to get a shop manual to troubleshoot the circuits.
Sep 22, 2012 | 2002 Chevrolet Impala
Dash lights flicker when ya turn key and wont start"" (then after you keep turning key serveral times lights quit flashing and car starts" what do you think it could be??
have battery checked, sound like battery weak or battery cables loose or battery post and cables need cleaning has a lot of corrossion.make sure you turn off radio before disconnecting negative battery cable if you decide clean battery cables and battery post,reason for turning off radio to keep from locking out radio play code.have battery tested battery volts should be 12.6 volts.
Feb 01, 2012 | 2002 Oldsmobile Intrigue
It wont play cd just keeps saying e1 eject cd radio plays fine
look for areset botton if it dosent have one by a cd cleaner if after that its the same replace the radio
Jun 11, 2010 | Panasonic CQ-DFX403U CD Player
My 1997 land rover radio just says code it wont turn on how do i get it to play music
look in your owners manual or if a radio manual came with it look there. there should be a four digit code there for the anti theft feature on that radio. The automakers put it there to keep people from stealing the stock radios from cars. It's mostly a pain in the patootie because most car thieves aren't looking for stock radios. Good luck.
Apr 23, 2010 | 1997 Land Rover Discovery
How to remove fan switch on 1999 oldsmobile alero or replace switch
FIRST OF ALL YOU NEED TO DISABLE AIR BAGS.TURN OFF RADIO FIRST SO YOU WONT LOSE RADIO PLAYING CODE.DISCONNECT NEGATIVE BATTERY CABLE. WAIT 15 TO 20 MINUTES UNTIL AIR BAGS DISCHARGE.TO REMOVE HEATER AND AC CONTROL SWITCH.YOU NEED A FLAT TRIM TOOL USE TO PRY UP TRIM AROUND CONTROL SWITCH.SO YOU CAN REMOVE CONTROL SWITCH SCREWS AND REMOVE CONTROL SWITCH.
Feb 26, 2010 | 1999 Oldsmobile Alero
Fiat cd changer wont keep its code inthe memory
The radio requires TWO battery feeds.
One is a permanent battery feeding the code and station memory
The other is the main one  via the Ignition Switch
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
KEEPS CUTTING OUT
put a cd cleaner in it and play it a few times should do the trick even if it won't play but for three sec.
Jan 10, 2009 | Car Audio & Video
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
