Question about Home
Qualceram cylix installation toilet replacement parts
Where will I get replacement parts for a cylix toilet
How do I get replacement parts for Caesar toilet
did you find parts for Caesar 1.6 toilet ?
I am looking for it also.. thanks
May 28, 2012 | RTO Caesar 1.6 gpf One-Piece Toilet with...
Toilet tank dose not fill up when i flush the toilet i have to open the tank and flip the leaver under the float
Go to an ace hardware or walmart and buy a replacement kit for the inside of the toilet. They do not cost that much and should be able to solve your problem just follow the diagram to install, it is fairly simple. Parts wear out and this will save you a lot of money from getting a plumber
Mar 31, 2011 | Kohler Home
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
Need parts for a 30 year old jacuzzi toilet
Depending on what the innards look like, you can spend $15 at a home center like Home Depot for a toilet replacement parts kit. They're easy to install (about 30 minutes) and fix most common toilet issues.
If this won't work you might need to contact a plumbing supply company in your area. You'd be surprised what they have in inventory....
Jul 23, 2010 | Jacuzzi Home
American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Sep 26, 2009 | Home
Describe your Eljer &
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Jul 17, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Home Logo
53 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
