LXR7244PQ0 whirlpool top load washer. Problem: Agitator spins when manually turned, wash fills, does not agitate, spin, or drain. I checked lid switch, couplers and rubber piece is fine on motor I have not checked the agg.dogs would they (agitator dogs), keep the washer from draining?
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whirlpool top loading washer will not spin or
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 18, 2009
  • 73 Answers
SOURCE: LXR7244PQ0 whirlpool top load washer. Problem:
Sounds like the motor coupling is bad- it keep the motor and transmission safe when overloaded and its cheap, if the motor is making noise that's the place I'd start. After that it's the motor (make sure it has power when it should) or the transmission- both not cheap.
Posted on May 16, 2014
LXR7244PQ0 whirlpool top load washer. Problem: Agitator spins when manually turned, wash fills, does not agitate, spin, or drain. I checked lid switch, couplers and rubber piece is fine on motor I have...
May 16, 2014 | Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
