Question about Philips Magnavox Learning Universal Remote
Neither my dish remote or tv remote works on my magnovox 42mf438b/f7
    Top Expert:
  • Philips Master
  • 11,573 Answers
Remote not work
If remote control is alright, the problem should be with the remote sensor inisde the TV. This is a three solder terminal component, can be located just behind the infrared sensor window at the front panel of the TV. You should have to open the TV, and unscrew out the PCB that this component have soldered in.c40243d8-cf4c-4923-b01c-275b76413f28.jpg
297f57d3-e54d-4a39-9705-1b60be54ed8c.jpg23707d23-08b4-4207-8360-4ae03fdb70ea.jpgThe component will look somewhat like these. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 12, 2013 | Televison & Video
Magnavox 42MF438B/F7 power light blinks for several minutes then goes solid but still no pic. cannot power box off with remote or power button on tv
1) you must open the remote code, and resolder all points colder points solder.
2) clean any keypads contacts, with special spray contact cleaner removing oxide, dust, etc.
3) Test the connection from power box, otherwise the button from power box is defective or clean with special spray contacta. unplugged the power box. and try.
4) if the problem persist you must go to the repair shop TV for fix it.
God bless you
Jun 28, 2012 | Televison & Video
Have a magnvox TV will my dish network remote work with it I am on cox cable all so dont know my code ??
I see you needed some help programming your remote, dgosch406, which I'd be happy to help with! Let me know the model of the receiver you have, which can be found on the front panel in the bottom left corner. Try the following codes for your Magnovox TV: 566, 770, 723, 506, 677, 724, 729, 762, and 610. If you have questions, I'll look forward to hearing from you!
Hope that helps!
Jul 30, 2011 | DISH Network IR Remote Control
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Need program instructions
I need the model receiver you have to do this.
Jul 25, 2009 | DISH Network IR Remote Control
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox Learning Universal Remote Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
