Question about Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43
How to replace belt on PCV43? - Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43
Need a manual for powemate Pcv43
If you mean the Powermate PCV43, the Powermate Outdoors site has the manual on the product page: http://powermateoutdoor.com/soil_preparation/PCV43.html . The link to the manual is just below the model number. The direct link is powermateoutdoor.com/pdfs/om_cultivator_pcv43.pdf . Since the PCV43 tiller is sold at Home Depot, the product page there also has the manual: http://www.homedepot.com/p/Powermate-10-in-43-cc-2-Cycle-Gas-Cultivator-PCV43/202674371 . On this page, look on right hand side of the page as you scroll down to the Product Overview section.
I hope this helps. (Note: you will need Adobe Reader or a similar program to read or print the manual.)
Apr 24, 2015 | Garden
Tiller idles but drowns out when i try to till
Adjust carb. Turn speed/air mix needle counterclockwise 1\4 turn.
Oct 18, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
What is a sparkplug gap for a powermate 43cc engine
Set spark plug gap to 0.024 - 0.028 in. (0.6 - 0.7mm).
Oct 11, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
How can you free fuel flow?
Hi Joe Rutkowski, Fuel lines with a pin hole can cause a problem with the fuel feed. The carb can have a closed choke or only halfway open. The return fuel line has junk in it, like dirt over a period of time. There is a screen inside the bottom part of the carb, it is called a manifold. When taken apart, you can see the screen or any other obstruction between the manifold. Be very careful not to tear the gasket, they are not easy to find sometimes. Be careful also and do this inspection on a clean surface where all the parts are visible. Good Luck!
Jun 06, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
How do you clean carburetor powermate 43 cc
I'm sorry to say that I had a similar problem, and after two trips to the repair shop, I gave up and bought a new carburetor at eReplamentParts for about $40. The new carburetor is working quite nicely.
Jun 03, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
My powermate 43cc cultivator not getting gas through carb
Replace the fuel filter. Check float bowl valve in carburettor
Oct 22, 2013 | Powermate 10 in. 43 cc Gas 2-Cycle...
What is the pston ring size
MIne too! I'm ordering some 43cc rings that seem to match the size of the one good one I had left. They are sold by many different eBay sellers and apparently are most all the same for a 43cc displacement piston....
43cc, OD=42mm, ID=38 mm, Thickness=1.5 mm
May 10, 2013 | Powermate 10 in. 43 cc Gas 2-Cycle...
Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43 Logo
Top Powermate Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Powermate Garden Expert? Answer questions, earn points and help others
