Question about Lexmark Ibm Lift-off Tape Easystrike 1337765
How do I make the correcting tape cover the whole letter instead of just the bottom half
The correcting tape only erases the bottom half of the letters
  • 453 Answers
Make sure it is firmly attached to the bottom of the black ribbon cartridge
Posted on Oct 25, 2014
  • 3594 Answers
SOURCE: Wheelwriter 1000
Be sure the ribbon dosen't have any folds in it and that it is properly inatassed also check around the ribbon for any debris.
DickyO
Posted on Oct 04, 2008
Geno111
  • 183 Answers
SOURCE: only part of the character/letter is showing
make sure the ribbon is latched into place (should lock down) also check on the ribbon itself to make sure the print is in the middle of the ribbon and not on the very bottom, if the ribbon is locked down and types of the bottom of the ribbon, it is out of adjustment. if the ribbon looks ok, move the paper scale (the plastic piece on top of the platen) up out of the way, then push down sharply on the platen. if it moves down and clickes into place, it should work OK.
Posted on Jan 06, 2009
  • 3594 Answers
SOURCE: Keystroke on prints top half of letter
Most likely the platen is not fully seated press firmly on buth ends of the platen (black rubber roll) it should snap into place.
DickyO
Posted on Jan 29, 2009
  • 3594 Answers
SOURCE: Letters and numbers not printing correctly
It sounds like you have a damaged printwheel. Get a new one and try it.
DickyO
Posted on Apr 29, 2009
  • 3594 Answers
SOURCE: Only a portion of the letters are printing on the paper.
Sounds like the platen has worked loose. press down firmly on both ends of the platen (black rubber rol) it should snap back into place.
DckyO
Posted on Jul 03, 2009
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
XEROX 6010 NOT ERASING
The adjustment on the L/O is a little tricky for the novice you probably need a tech.
DickyO
Oct 31, 2012 | Xerox 6010 Memorywriter Electric...
The bottom half of letters are not typing. I just
First be sure the platen is fully seated and locked in the side frames, Then be surethe ribbon is on allthe way, then try it without the L/O tape.
DickyO
Jul 13, 2010 | Brother SX-4000 Typewriter
Typewriter won't erase letters completely.
Correction tapes do have a shelf life and can dry out. You should try replacing the correction tape and see if it is better. If that does not fix it, does the tape lift up high enough to cover the entire letter? If not, you have a lifting problem and will need a tech to fix it.
May 28, 2010 | IBM Wheelwriter 6 Typewriter
I have an AX-22 and when I replaced the correction
You probably don't have the dull toward the paper.
DickyO
Mar 15, 2010 | Brother Office Equipment & Supplies
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
Brother EM-530 corrective tape appears to be broken
Be sure the tape is installed with the dull side facing the platen. The tapes are readly available but be sure it is a dry L/O tape General ribbon T355 or equivlent.
DickyO
Jan 29, 2009 | Brother EM-530 Typewriter
Changed correction tape but still won't work
either; 1. you have a non-correctable film ribbon, (it should say correctable film ribbon on the box or the ribbon itself) you can check by taking a piece of scotch tape, hold it next to the letter you want to erase, sticky side towards the paper, and hit the CORR key, CAREFULL YOUR FINGERS AREN'T IN THE WAY. if it corrects, the ribbons ok. 2. make sure the DULL side of the corr. tape is faced toward the paper
Dec 02, 2008 | Brother GX-6750 Typewriter
Eraser
Yeah, a strong magnatic field can erase whole tape at once. You can try it by using Deggausing Coil at TV repair shops, though i have not tried it yet.
May 22, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Lexmark Ibm Lift-off Tape Easystrike 1337765 Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
