Question about GE JKP15 Electric Single Oven
My jkp15 oven is on but not heatiing up
THE OVEN JUST STOPPED WORKING THE OTHER DAY.WORKED FINE UP TILL THEN.A DAY BEFORE THE TEMP DID NOT GET TO WERE IT WAS SET AND THE NEXT DAY NOTHING.BREAKER WAS FINE,RESET IT ANYWAY STILL NOTHING.CONTROL PANAP SEEMS FINE ,ANY SUGGESTIONS
  • 213 Answers
SOURCE: MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Posted on Nov 19, 2007
  • 10 Answers
SOURCE: Double oven control keeps failing
This is a common problem, try http://www.fixya.com/howto/h155060-dreaded_f7_error
it worked for me.
Posted on Aug 20, 2008
  • 157 Answers
SOURCE: No heat after cleaning cycle.
set clock
Posted on Jun 30, 2009
SOURCE: oven lights and works fine till it reaches set
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Posted on Jan 25, 2011
blackmar
  • 235 Answers
SOURCE: oven shut off - no power- checked circuit breaker
This sounds like the thermal overload operated and turned the oven off. The overload is generally located in the top of the oven cavity. Remove the top cover and you should find it. Sometimes it open circuits the active supply and sometimes the neutral. Sounds like it may need replacing.
Posted on Feb 16, 2011
Ge jkp15aa
Take the back off the control panel and see if you can access the board. If you can see the board component side, go to radio shack and fgget freeze spray. Start the oven and when it quits like you described, spray one part on the board at a time till it comes back on. OR buy a new board
Feb 07, 2013 | GE JKP15 Electric Single Oven
My broiler element has burnt out and i need a replacement its a GE built-in oven model number JKP15
See this link, then click on the exact model number for your appliance. Navigate to the section of the oven containing the part you require:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JKP15
Apr 02, 2011 | GE JKP15 Electric Single Oven
GE JKP15 does not self clean and minutes cant be set on clock
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Mar 30, 2010 | GE JKP15 Electric Single Oven
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
GE JKP15 and i get a F2 when i try to bake.What does this mean.
F2 means excess tempretature was detected by a secondary sensor mechanism. i.e. the promary has failed to detect. You may have to replace the temp sensor.
Oct 16, 2009 | GE JKP15 Electric Single Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Bottom /bake element will not come on
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Jul 21, 2008 | GE JKP15 Electric Single Oven
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven Logo
65 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
