Question about Epson Stylus Photo R200 InkJet Printer
No power , unit will not turn on, I checked conections,switched outlets, etc. Is there some othe rposibility?
  • Epson Master
  • 511 Answers
No power? have you checked output voltage of PS? Or it just switch button damage. Open case, check electricity at front panel board.
Posted on Jun 24, 2009
Whirlpool wed5830swo
Did you remove back and check incoming power at outlet and at inside back of unit with voltage meter?
Sep 07, 2014 | Dryers
My spirit sr275 treadmill will not turn on after losing power.
check the over load reset button ,motor,switch etc.
Aug 09, 2014 | Spirit Exercise & Fitness
Honeywell hz-710
Hello, welcome to Fixya!
Your unit is having a power fault because it is not switching on. The unit might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the unit is having a power fault.
When electric current comes from the power outlet into the unit, it goes straight into the power supply board which then circulates the current into the unit. So if the unit doesn't power on, the first thing is to make sure there is power entering into the unit.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store within your vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Nov 05, 2012 | Honeywell HZ-710 Oil Filled Radiator...
The tv turn on when i conect to the outlet
What is the full model number of this set?
May 16, 2012 | Televison & Video
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
The TV doesn't power up anymore - i've checked the cord connection, made sure the power switch is in the "on" position, etc. basically ran through all the possible troubleshooting solutions. ...
If power reaching unit and after all you have checked, it appears the PS is fubar. Easiest thing to do is check for swollen/leaking/blown capacitors and replace them - cross your fingers and turn on.
Sep 04, 2017 | Maxent MX-26X3 Television
The unit just stopped working and will not turn on
I'm assuming 'nothing' comes on when you try to run the AC unit. If the fan runs but the AC does not cool then ignore the below info, but if "nothing comes on" then proceed with the below info.
If the breakers are not tripped and you've tried other outlets (on different breakers) I would suspect a faulty switch. You can replace the switch ( If it's not computerized). First unplug the unit from the wall and locate the switch (it will be the one that has the knob that controls "fan, Hi Cool, Lo Cool, etc etc.) then remove the switch - 'being careful to mark all the wires in such a manner you can replace them on the new switch, exactly like they came off the old one.'
Then if you take the switch to an appliance shop and can find/order the 'exact' same switch (or at least a comparable replacement with the same connections as the old one) you could re-install it on the unit, connect your wires back up to the switch and plug it back into the outlet and see if that was your problem.
good luck!
May 03, 2010 | Goldstar M6004R Air Conditioner
Dishwasher won't run
some whirlpools have fuses in the control
panle
Jun 23, 2009 | Dishwashers
Memory not working
check the yellow wire is the main power so always need to exist power on that wire even if the key is not on the ignition switch,and the red wire need to be conected to a switched ignition wire from the vehicle.
Mar 23, 2009 | Pioneer DEH-1100 CD Player
My hp desktop computer will not turn on
If you cant see or heard any boot up sounds, fans and especially if you dont see any power or green led lights at all ;
If your power cord is plugged into a power strip or surge protector, power cycle your strip or surge protector by turning off and on.
If power outlet has a wall switch make sure its on
Check that your power cable is securely plug in to both ends
Check that at the back of computer, specifically on the back of the power supply unit that the switch is on "1" position and NOT on the "0" position ( 1 is "ON" , 0 is "OFF" )
Check that the power outlet is not damaged by pluging in another good known device (such as a blowdryer, shaver, lamp, radio, etc, etc) to see if its the power outlet or not.
Can you see power or green led lights and hear the fan on but no display ? If this is the case , check your monitor connection at both ends. If they are secured open up your case and see if you can smell any burnt smell or check that all cards especially video cards are properly seated.
Jan 21, 2009 | E-Machines eMachines Desktop PC
Epson Stylus Photo R200 InkJet Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
