Question about Wurlitzer Rock-ola Jukebox
How do I reset my rockola 5500x rocket jukebox?
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Need to turn the volume up on my rock ola model 7000 2bx
This is a link for contact info....
http://www.rock-ola.com/Pages/contactus.aspx
Feb 27, 2015 | Wurlitzer Rock-ola Jukebox
I have a Crate g120 cxl guitar amp. it is switching between channels on it's own. (no footswitch)
Hello Jamie.
Your right, it is not rocket science, this is way bigger and funnier!
Now, that you took apart the chasis fron the cabinet, you may try testing if the channel switching occurs when you hit the Printed Circuit board with some tool like the handle of a screwdriver. you can try with light hits and different places of the PCB while watching what happens in the front panel light. also you can try bending the PCB with your hand to see what happens, if the switching occurs, maybe you have a cracked solder on the pedal jack or in any component related to the switching circuit, in this case, you will have to pull out the pcb, and re-solder those points that can be cracked. Using a magnifiying glass is very helpful in looking for those cracked solders.
Good luck and best wishes.
Nov 21, 2014 | Crate Music
Rockola jukebox 484 turn table does not turn,
Drive belt for the turntable is most likely broken. Need to replace it.
May 18, 2014 | Music
Rockola 470. How can I convert my 240v 50hz to 110v 60hz to supply my jukebox?
2 choices: replace power supply transformer or replace motor to get the right speed and the right sound pitch.
Sep 05, 2013 | Wurlitzer Rock-ola Jukebox
Been given a grade 5 Rockola 160 433, need a copy of the service manual
Contact the folks at www.victoryglass.com and tell them the make and model of your jukebox. They will have the manual set for around $50. Also, they bought out the entire Rockola factory parts inventory. So if by chance you needed Rockola parts, they would have it.
Aug 05, 2013 | Wurlitzer Rock-ola Jukebox
Rock-ola cd jukebox bubbles wont bubble?????
They are probably made like the old Christmas tree bubble lights. These had a solution, I think it might have been calcium chloride and they were heated at the bottom end of the tube by an incandescent lamp that ran pretty hot. The lamps in your unit might be burnt out. I remember we had to tap the tubes lightly to get them to start bubbling sometimes.
Feb 16, 2011 | Wurlitzer Rock-ola Jukebox
I have a Rockola jukebox model 456.It worked well overall,but now it will not reject the records after play?What should I be checking?
You might want to try this forum:http://www.antiqueradios.com/forums/viewtopic.php?t=104054&highlight=&sid=231c6e27ef15ccbe83c7a412bb9c8b86 The part in the post about lubrication is important but might not be the solution to your problem. I would suggest joining and posting as there is probably other owners who are members.
Mar 25, 2010 | Music
Open Questions:
See all Wurlitzer Rock-ola Jukebox Questions
Wurlitzer Rock-ola Jukebox Logo
52 people viewed this question
Top Wurlitzer Music Experts
rostit
uwbfritz
Are you a Wurlitzer Music Expert? Answer questions, earn points and help others
