Question about Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
This is my 2nd one of JDS9865BDP which was exchanged through Jenn Air and the burner will not adjust on the left side, it is too high
    Problem Solver:
  • 17 Answers
These micro switches are standard parts and are available from commercial electronics stores - one of which is Active Electronics in Toronto. A second one is Electrosonic.
Posted on Jul 28, 2009
  • 64 Answers
Because thats the grill side they wont adjust they are not suppose to
Posted on Jun 23, 2009
I have a Jenn Air Gas Range Model # JDS9865BDP that is set up for LP gas. What other adjustments are needed other than replacing the burner orifices / spuds and converting the pressure reg to Nat gas?
You will need a new data plate from the manufacturer. This should come with a conversion kit that wil contain everything you need to do the changeover
Jan 08, 2018 | Jenn Air Kitchen Ranges
JDS9865BDP door won't close
Could you please describe the problem you are having a little better?
Nov 27, 2012 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Spark module location
BTU output on high is not very hot anymore
Mar 01, 2012 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jennair model # JDS9865BDP Dual-Fuel Modular slide-in Range Pro Style Burners are too hot to do regular moderate cooking. Wife says the left side burners (where grill goes)can't be adjusted low enough to...
pull off your selector knob and shine a flashlight down the shaft, depending on your model, you may have the adjustable mmodel
at the bottom of the selector shaft, you may see a flat head screw adijudt it at ver small increments
i believ a 1/4 turn in should turn your flame down quite a bit
hope thsi helps
Nov 02, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Two from burners will not start , unless a match is used
Check the position of the ignitor that sparks, compare it to the burners that do lite.
The other one may ne replacement
Mar 18, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Apr 06, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Air JDS9865BDP Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
325 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
