Question about NTI Backup Now EZ
System back does not work
The systems backup will not work
Restore dell vostro win8 to factory setting
  1. Plug in the AC adapter.
  2. Point to the right hand corner of the screen to bring up the charms bar.
  3. Click SettingS
  4. Click the shutdown button, hold down the <Shift Key> and click Restart from the options provided.
  5. The system restarts, login and click Troubleshoot.
  6. Click the Dell Backup and Recovery icon.
  7. The system restarts and comes back up, click Next on the Dell Backup and Recovery Screen.
  8. The system restarts and comes back up, click Next on the Dell Backup and Recovery Screen.
  9. You will be prompted to select the backup to be used, click the factory image option or select from one of the backups. Click Next.
  10. You will be prompted to backup your files, if needed do so by selecting the option Yes, backup my personal files (Make sure to have an external backup hard drive handy.) or select No, Erase my files.
  11. The system goes ahead and completes the restore of the operating system. Click Restart when prompted.
  12. Follow the on-screen instructions to setup the system with windows.
Jan 23, 2014 | Dell Computers & Internet
I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
You have a varity of option to do your backup depending on the type of backup you want to do.
1 Documents and folders
To backup your document and folders you can just copy the Documents and folders to the external drive.
You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
2 System backup of your system.
You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
Windows Back for Windows 7.
Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
This will save your files to the external drive you added to your system.
Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Upgrade wiped out game memory
Hi
Did you take a backup of your game saves or the system backup before upgrading the firmware of your PS3? if not then there is no method to retreive your game saves, however i am listing few steps for you so that you can take a backup in future before you upgrade your PS3
Game saves are of two types, the first ones are those which you can take on any memory stick (cf, ms duo, sd) and there are few saves which cannot be taken on a memory stick due to copyright issues, here you would have to take a full system backup and would require a external Hard Disk to save or a memory stick with a larger capacity.
Steps for Game Save Backups only
1. On the XMB (cross media bar), go to the Game section.
2. Go to Game Saves
3. Put in your memory stick
4. Find the game save you want to copy/backup, highlight it and hit the Triangle button.
5. Choose the menu option to Copy
6. Hit the X button on the memory stick and let it copy.
Steps for System Back up
In the XMB, go to System
Go to Settings > System Settings > Backup Utility
Then choose Back Up
Finally, pick the device to backup too (memory stick, usb harddrive, etc).
While doing a system backup all content of your PS3 including videos, music etc. would be included in the backup, however if you have purchased any copyright material, it would not get restored even if you do a complete system backup
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
How to backup windows 7 on acer aspire 5532
use "back on ur computer" option from control panel to take backup in windows 7
Nov 27, 2009 | Computers & Internet
Windows Backup
The backup program only came installed in the Pro version. In the Home version you need to install it from the original operating system CD. Put the CD in the drive. Goto Start, Run and type (CD Drive):\valueadd\msft\ntbackup. This will install the backup program.
Apr 06, 2009 | Computers & Internet
Clicking
that's a sure sign that you are in low battery condition, and the inverter is approaching shutdown. You may need to either deep recharge the batteries, with NO load, or replace them completely.
Got Backup?
Feb 10, 2008 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Dec 02, 2007 | Microsoft Windows Server Standard 2003 for...
Active directory
you can use in built ntbackup utility.
In a DC, in the Items to backup window, expand Mycomputer and you can see System state. select that and proceed. It will take the Active Directory data.
Nov 06, 2007 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
94 people viewed this question
Top NTI Computers & Internet Experts
Lawrence Oravetz
k24674
richie46
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
