Question about HP Photosmart C7280 Laser Printer
Hp c7280 will not send or receive faxes. phone is hooked up thru it and it works fine. c7280 does not recognize phone when it is off the hook. it used to.
  • 163 Answers
SOURCE: Fax shows an 'off-hook' status
pleaz check the hook sensor
Posted on Sep 16, 2007
map9966
  • 2351 Answers
SOURCE: HP210--eroors "Phone Off Hook" when trying to receive a fax with the answering machine on
Not broken.
This site should help you:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00036550&lc=en&cc=us&dlc=en&product=79499&rule=42022&lang=en
Posted on Dec 04, 2007
Silan
  • 54 Answers
SOURCE: Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
Posted on Dec 22, 2007
SOURCE: phone off hook error message
Printer comes with "Line interface Unit" short black phone cord (male to female) this must be plugged in between printer and phone cord.
Posted on Jun 11, 2008
SOURCE: hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Posted on Sep 27, 2008
I have a hp photosmart c7280 all-in-one printer fax copier scanner when some one sends me a fax it wont go through when i access the tool section on the printer and try to run a test page is says fax...
chances are your phone line is not a dedicated outgoing data transmission line : result of the phone companies keeping tabs on their property and its usage. if you are using a regular phone line, you have to call for the phone co. to add the data transmit feature.
Jan 19, 2012 | HP Photosmart C7280 Laser Printer
How to hook up fax on HP C7280
The C7280 can be used as a stand-alone fax machine. All you need to hook up to the printer is a telephone line. Connect the phone line to the jack marked "1-Line" on the rear panel, below the power supply connector. If you want, you can connect an extension phone to the jack marked "2-Ext". The line connection is for a standard telephone line. Once the line is connected, faxing is pretty much the same as it is on any fax machine. Put your documents face up in the feeder on top, or for a single sheet, face down on the scanner glass. Press the "Fax menu" button on the control panel and you'll be asked for the number. Enter the number from the keypad and then press the "Start fax black" or "Start fax color" color button to send the fax. Other than the phone line, there isn't anything else you need to hook up.
You can download the manual from HP if you need it for reference. It explains how to use the special features of the fax machine, like broadcast faxing, memory dialing, printing fax reports, etc.
Aug 17, 2011 | HP Computers & Internet
Can't use fax on HP C7280
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | HP Photosmart C7280 Laser Printer
HP 5780 will not receive a fax.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } There would not be problem in phone line. please slect slect appropriate option in data fax mode.
slect it to the recieving mode.
hopefully it will work fine
Sep 03, 2009 | HP Officejet J5780 All-In-One Printer
Fax All in one hooked up to pne jack (directly) and the hooked 2-ext to phone . Can send but not receiving
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab80
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot receive a fax but can send one out
Make sure your phone lin is plugged in the jack on the machine that says LINE not the jack that says TEL or PHONE. I have seen this before. the unit gets a dial tone and can send but will not answer.
Hope this helps
Mar 11, 2009 | Canon Office Equipment & Supplies
Cant recive fax
Ok - phone off hook is a message on the printer because you are on the phone. There is a phone that is up somewhere in your home that it can recognize. You cannot send a fax or receive and be on the phone at the same time. This can also be caused by credit card machines, internet service (filter needs to be on fax line), and other fax machines.
To the original poster - your question is fairly vague. This hp link solves the most common issues when you can send but not receive.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01503742&lc=en&dlc=en&cc=us&lang=en&rule=21569&product=391182
Sep 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP Photosmart C7280 Laser Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
