Toshiba 15vl63b how to open panel lock
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
Toshiba satellite c655d-5332 keys problem
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Sep 23, 2012 | Toshiba NB205-N210 Netbook
32"toshiba regza no picture/ sound ok
lock for picture on the lcd but thi picture have to be very dark open it check for blown capacitators or blown fuses :D
Sep 22, 2010 | Toshiba REGZA 32RV530 31.6 in. LCD HDTV
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Input Lock Reset
Toshiba 42HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tv wont start up!
Power supply issues I bet.
A good servicer can replace or repair.
Blessings,
A/V Guy
Jan 31, 2009 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
