What does seatools test code E59FC6EE indicate?
    Master:
  • 568 Answers
Please mention the code properly
Posted on Feb 02, 2016
What does SeaTools Test Code: EB65D7EA mean
SeaTools Test Codes
When SeaTools for Windows determines that a drive has failed a va
lid warranty test, it will display this File Info icon:
Selecting this icon will display a box with three tabs of information about the failure - hints, warranty checking with a SeaTools Test Code
and the log file with test results. This is a typical example:
SeaTools Test Codes are based on the type of test that failed and the product serial number. No two codes are the same. The online RMA submission system will use the SeaTools Test C code number to help process the exchange of your product. The code tells Seagate that
the drive is, in fact, bad and that there is virtually no chance that a good drive is being returned.
When you submit a drive for return to Seagate through the online Warranty and Returns process, the form will ask for your Serial Number, Model Number and SeaTools Test Code. External USB products like FreeAgent and OneTouch do not have ST model numbers. Instead, they have Part Numbers printed on the
plastic case enclosure. You will need to use that part number when
returning a USB drive
Jul 07, 2014 | Computers & Internet
Simpletech external hard drive has a constant red light and is no longer recognized by my laptop
It sounds like the drive could have failed. Try running a test on it using Seagate Seatools:
SeaTools Seagate
Mar 20, 2014 | SimpleTech Computers & Internet
Storejet 160gb
I have had just had this issue with one of my clients external drives. In most cases it will either be the outer shell/usb headers that are faulty or the hard disk itself is faulty.
The power light coming on, the drive spinning up, light blinking etc are good signs but by no means an indication the drive is in anyway working.
It is quite likely your drive has failed. To check this I would extract the drive from the external USB shell/caddie and connect the inner hard disk through other methods. For example another USB caddie. If you find the drives detects, installs and operates ok you can safely assume the previous shell/caddie was at fault. If you find the drive still does not work I would run a test with Seatools:
SeaTools Seagate
If the drive fails Seatools diagnostics or simply does not get detected by the system I would say the drive had failed and needs replacing.
You may want to recover your data if drive failure is the conclusion of testing, this free tool may be helpful to you in that case:
Recuva Undelete Unerase File and Disk Recovery Free Download
Alternatively data recovery specialists could be helpful to you, below is a link to a company I can recommend:
Fields Data Recovery
Mar 18, 2014 | Computers & Internet
Boot mng missing
Your hard disk has possibly failed, I would run tests on the hard disk, using another machine or caddie. The software I recommend for testing the hard disk would be "Seagate Seatools", which can be downloaded here:
http://www.seagate.com/gb/en/support/downloads/seatools/
This software should confirm the current state of your hard disk.
Mar 18, 2014 | Dell Inspiron 1545 Notebook
Hi , I have problem in my hard disk ,, I con't open my files :''( this masg is " this request can't be performed because of an i/o device error " help me plz :(
I/O device errors are rarely repairable without buying new hardware. Test the drive with manufacturer's diagnostic software. Toshiba do not have any such software but you can use SeaTools for Windows:
Click Downloads here: http://www.seagate.com/support/downloads/seatools/
Choose the Long/Extended test for thorough testing of the drive.
Oct 05, 2013 | Computers & Internet
My dell optiflex system started acting slow. OS installed is windows 7, Ram - 4GB usable - 3GB. i re-installed the OS using the re-installaation CD provided by DELL but found no improvement. i woould...
Test the computer's Hard Drive. There are a lot of reasons you might want to test your hard drive for problems. One of the major reasons to perform a test would be if your hard drive is making strange noises. This can often be a sign of a failing drive, something a test can point out.
If the problem is a software issue (virus or too much software installed on the PC) running a System Recovery should have fixed the problem. Try running a test on the computer's Hard Drive. A failing Hard Drive causes slow performance (slow boot, slow computer performance, programs takes too long to load or will not laod at all). And another indicator that the Hard Drive is failing is clicking noises. If you hear clicking noises, backup your files as soon as you can.
You can use free Hard Drive diagnostic tools what can be downloaded from the internet. One of them is Seagate Seatools.You can download it from here - click this link
SeaTools for Windows can perform several basic tests that can help determine the health of your hard drive. Your available hard drives and tests are easy to see when the program opens and can be ran with just a few clicks of the mouse.
Hope this help. Goodluck!
Apr 07, 2011 | Dell OptiPlex 780 DT/ 780 MT/ 780 SFF...
My Maxtor 250GB just stopped working all of a sudden. When I connect to the computer, all it does is a whirring sound like it's trying to boot up, but it does not open so that I can access the data. What...
Best to Download Seatools from the Seagate website. You probably have a 5 year manufacturer's guarantee and you can test and possibly repair it with Seatools before having to returning it with Seatools results to get service, which is only free if Seatools finds it Faulty.
Dec 12, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Error 01-0134-0000?? It says the tool could not get HDD physical information? Is my hard drive fried? Or what else could it be? How do I fix it?
I suggest you download a free HD test and check the HD. I like to use Seagate's SeaTools, which work for ANY brand of HD. Go to the Seagate website here:
http://www.seagate.com/www/en-us/support/downloads/seatools
and download "SeaTools for DOS", Be sure to get the "v1.10 (Text) English", the ona under the "ISO CD-ROM Image" column. This will download an ISO CD image that you need to burn onto a CD. This will create a bootable CD that you use to boot your computer from (no OS needed). Then, run the HD tests for as long as needed (it may take a couple of hours to run, depending on your HD's capacity). SeaTools will diagnoze your HD and tell you if there is an irrecoverable hardware error.
Mar 28, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Error code 0X80070571 with the external HDD
The Seatools test has verified that the "physical" hardware is working fine, which is good news.
However, the error-message "disk structure is corrupted" means that there is a "logical" problem. Compare it to a book with a Table of Contents that has been overwritten by a two-year-old with crayons;
the pages are not physically torn nor missing, but you cannot "read" the original Table of Contents information.
Connect the drive, and note which drive-letter that Windows assigns, e.g., 'E:'.
Click Start
Click Run
Type CMD and press ENTER
Type CHKDSK E: /F and press ENTER,
and let Windows try to reconstruct the Table of Contents on the disk.
Jan 02, 2010 | Maxtor Personal Storage 3200 (M1227310)...
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Open Questions:
    Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
    Oct 23, 2017 | Major Computers & Internet
    Computers & Internet Logo
    43 people viewed this question
    David Payne
    David Payne
