Question about Pride Sundancer 3 Wheel Electric Scooter
How to remove a power seat motor in a 2007 grand caravan
The driver seat power now works up and down and back reclines but will not move back and forward. Any ideas on what to do...It is a Grand Caravan 2006....Thanks
Either the switch or the motor is defective. You need to purchase the repair manual. It's an easy repair burr the manual will show you which wires to jump once you remove the switch, this way you can determine whether the switch is faulty or the motor. If bypassing the switch makes the seat operate correctly then the switch is the culprit. If not then it's the motor 9 out of 10 times it's the switch.
Feb 10, 2015 | 2006 Dodge Grand Caravan
I need wireing diagram for a caravan plug for a 2007 jeep grand cherokee
Check on your motor you have some where a place how you have your number of your celynder
Jul 16, 2014 | 2007 Jeep Grand Cherokee Overland
The drivers seat will not recline, the seat still moves back and forth
Someone will have to remove the seat and check the motor and linkage to see what is broken.
Jul 25, 2012 | 2006 Dodge Grand Caravan
Driver Side Power seat quit moving forward and backwards. Is it difficult to remove the seat and replace the motor? Do you have instructions to remove the sesat
Honestly,
If you are considering this as an option, you probably have all the tools, a simple set of sockets will get the seat off - but use long handled tools as they are very securely fastened. Once you have the seat off, I would actually remove the sliding mechanism from the seat itself to gain access to the system much easier. Remove the motor, check the fuses or anything else while you are down there and then re-assemble with a new motor making sure to re-attach everything with the same "security" as the factory.
Feb 28, 2011 | 2000 Dodge Grand Caravan
2007 dodge grand caravan . using alot of oil with
5000 is too long in between oil changes for that vehicle. Change it every 3000
Feb 23, 2010 | 2007 Dodge Caravan SXT Minivan New Cars
Is my back door on my 2007 dodge grand caravan automatic
chrysler/dodge minivan keyfobs may contain a button for the automatic door/hatch when it is not equipped does the overhead console contain a switch for the door or hatch? if it does then somethings wrong if it doesnt its just another button on your keyless :)
Nov 19, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Remove 2004 Dodge Grand Caravan D-pillar panel
To remove the panel completely. You must remove all screws & the seatbealt bolts for the 2nd & 3rd seats
Oct 13, 2009 | 2004 Dodge Grand Caravan
Pride Sundancer 3 Wheel Electric Scooter Logo
23 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
