Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
I plugged my 110v bose sound link 30 into a 220v outlet since . than its playing intermittently with out the bass
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 183 Answers
There is a good chance the device is damaged beyond repair and it may require replacement.
Posted on Jun 03, 2014
3 Suggested Answers
cjackHD
  • 71 Answers
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Posted on Jun 21, 2009
freetek
  • 5568 Answers
SOURCE: Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Posted on Apr 10, 2010
Testimonial: "Thanks for the insight! I noticed that when I unplug the power cord, the amplifier makes a loud crackling noise. I'll investigate."
My son accidentally plug a 110v bose 3-2-1 to a 220v outlet. What do you think is the damage? Do we still need to send it to a service center?
If you are lucky you would have lost the fuse on the sub woofer module which powers the whole unit. If not, yes you will need a qualified technician to look into the matter because its not a small offense to plug a 110 device into 220v.
Jul 06, 2011 | Bose 3 2 1 GSX System
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
Moved back to South Africa from Los Angeles. Brought my Bose wave with me. 110V in the U.S., 220V in South Africa. Any advice how to make it work here. Don't want to damage it in any way. Please...
You need to get a stepdown autotransformer that takes the 220~240vac input and step it down to 120vac (BOSE can handle 50 or 60Hz line frequency), the problem will be getting one with the NEMA5-15R US style outlet so you can plug your BOSE into this step down autotransformer.
Learn more about plug types and voltages around the world:
http://en.wikipedia.org/wiki/AC_power_plugs_and_sockets
http://en.wikipedia.org/wiki/Mains_power_around_the_world
Hope this help.
Dec 30, 2010 | Bose Wave Radio
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
I have a problem adjusting bass and treble. I have too much bass when playing the TV so I adjust the bass down to get the proper balance. Then, when I play a CD, the bass is almost gone and I need to...
Figure out why the TV has so much bass. Look into its audio controls. I'd also consider attaching and listening to the TV-related audio directly and digitally through the Bose from the source(s) rather than through the TV and its questionable electronics.
Jul 15, 2010 | Bose 3 2 1 GSX System
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Sound cuts out from time to time
Hi, your system has some problem on the bass module which overheats the thermal sensors built in the bass module/subwoofer. I recommend that you bring the bass module to the Bose service center near your location.
That is the only solution...
Mar 18, 2009 | Bose Lifestyle 18 System
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
229 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
