Question about Bosch 4000 - 07 Electric Table Saws
My bosch table saw runs slowly backwards what part do i replace
  • David Ford
    David Ford May 11, 2010
    K lets start with the model number. I am confused with what you mean by "backwards" is the saw running in reverse? Have you done any repair work to the motor in this tool? Let me know and we will see what can be done/
  • Mario montoya Mar 27, 2013
    yes i have the same problem with my bosch table saw 4000 it run in reverse and slow, what's the most comon part to replace about this situation?? please any comment it's very welcome...
  • 154 Answers
Replace the field coil. I'm going to bet its a Model 4000. I have done about 100 of these saws in the last couple of years and my customers always complain of the same problem, "the saw was running backwards"
Change the armature back bearing while you have it apart, they always seize eventually.
Posted on Jun 23, 2009
2 Suggested Answers
SOURCE: bosch 4000 table saw run
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Posted on Oct 31, 2011
What causes my bosch 4100 saw to run slowly backwards
sounds like a 3ph saw that is single phasing in the wrong direction..need some more details of your saw...
Jul 12, 2014 | Saws
Bosh 4000 table saw runs backward and at low speed
I've worked on some table saws with problems like you describe, a couple needed a new speed control unit (Bosch PN 2610997306) in the motor. If all the wiring to and inside the motor is OK and not shorting out anywhere, that's the next part you should look at.
Jul 10, 2012 | Bosch 4000 10IN Table Saw
Just replaced speed control unit and saw still spins at very slow rpm, guessing 20-30. any other possibilties. any way to check if new control unit is no good?
With the saw unplugged, turn the saw blade.
If it turns easily with no hangups I would guess its the field.
When mine went bad the blade went backwards very slowly.
I replaced only the field and not the armature and it's worked fine for over 2 yrs.
Right now I have it apart to change an armature bearing which was completely frozen up.
Aug 29, 2011 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 table saw run backward and slowly
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
My 4000 started running backwards very slowly - is it a field winding or maybe the speed controller? And if it is the speed controller, where is it and can I bypass it to test it?
I am not aware of any speed controller on this tool. what I would do is unplug tool and turn it on its backside and look at the switch to see if possibly burnt causing problems.
Aug 23, 2010 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 Table Saw running backward
You can find the 4000 manuals and parts diagram at bosch tools online. You will need a new armture Bnew bushes and possibly field. I would also replace the bearings and motor speed control circuit board.
Bosch does not sell the motor assembly.
Turn unit upside down and remove the Plastic body - approx 6 screws.
Thake a digital camera and take LOTS of pictures of dissassembly as you will need them later. Blow unit clean and work neatly keeping all parts in labeled bins for reassembly. Don't attempt this job when your pressed for time.
Before you start check to see if this machine is still under warranty!!
Call customer support listed on website if you run into a problem.
Good Luck !!
May 19, 2010 | Bosch 4000 Factory Reconditioned 10"...
Saw slowed down. Shut off saw and restarted. runs backward.
Sonmethings shorted out inside motor / strip and see if any debris is in there.
It has somehow repolarised from the negative side to pos side!!
Jan 20, 2010 | Bosch 4100 10" Worksite Table Saw
Saw is rotating backwards can you help. its a power devil table saw
This happens with Bosch saws once in a while. The field coil in the motor short circuits. This causes the saw to run very slowly or sometimes run backwards. I sounds like yours has this problem. Unfortunatly the only way to repair the motor is to replace the field coil. This is a fairly involved repair and you might benifit from taking to a power tool service center.
Aug 05, 2009 | Saws
My saw runs backwards too!
Try to put the blade in the other way. then see if it works.
Dec 31, 2008 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 tablesaw suddenly ran backwards and died
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Dec 02, 2008 | Bosch Electric Table Saws
Bosch 4000 - 07 Electric Table Saws Logo
1,431 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
Tim Venetis
Gary Nitowski
Are you a Bosch Saw Expert? Answer questions, earn points and help others
