Question about Invicta Watches
Find invicta watch model #12471
Need setting instructions.
  • 4 Answers
SOURCE: problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Posted on Dec 12, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 2501 Answers
SOURCE: Operating instructions for Invicta Sea Wizard
Go to the "invicta.com" web site.
Put your cursor over "collections" and select "Instruction manual".
There appears to be only one manual covering all their watches.
Posted on Jan 06, 2010
  • 12 Answers
SOURCE: I just received my invicta reserve subaqua
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
You must set the Reference time first (page 18).
Posted on Jul 15, 2010
  • 12 Answers
SOURCE: Neeed manual for Invicta 4047 Atomic Watch
The Atomic watches set date & time automatically. The general instruction book applies to the alarm & chronograph features.
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
I bought a invicta watch model number 6620 and i dont know how to change the day setting. It reads wed but i need it to be sat.
The Instructions for Invicta watches can be found here:
the instructions are organized by the functions of your watch , not by model number. Refer to page 6 of the pdf file to find the instructions for your model.
Mar 26, 2011 | Watches
Need manual to set model 3065
Their web site gives a list of generic instructions which you need to scroll through to find the section that suits your watch.
You can get an instruction manual by going to their web site
(www.invictawatch.com/), put your cursor over "collections" in the
menu across the top and then clicking on "instruction manual".
Click on the link below the "Invicta" logo and download the instructions.
Mar 13, 2010 | Invicta Sapphire Diver 7049 Watch for Men
Setting the day on model 6214
Unfortunately the Invicta manuals do not show instructions by model numbers, only by diagrams.
Their instruction manual is a generic type which covers all their watches and you need to scroll through a list of instructions to find the one that is suitable for your watch.
Go to "Invicta.com" and put your cursor over "collections" and a drop down menu will appear on the line below. Select "instruction manual" and read through the diagrams to find what you need.
Feb 02, 2010 | Invicta Watches
Need the instruction manual for model 5392
Go to the Invicta web site (www.invictawatch.com/) and put the cursor over "collections" and another menu will appear. Select "instruction manual" and on the next page select the PDF file at the bottom of the Invicta logo.
An instruction manual appears that cover all their watches. Read the section that deals with your watch.
Jan 31, 2010 | Invicta Watches
I need help setting a Watch Activa AD 004-002
The Activa web site has no offering for instructions but it says that they are part of the Invicta group. You could try the instructions on the Invicta web site.
To obtain these go to "Invicta.com", put the cursor over "collections" and click on "instruction manual".
On the next page click on the link below the Invicta logo and a set of instrucitons appear.
This set is rather a long one that covers all the watches that Invicta make, so you may have to search for a while to find one that looks like yours.
Good luck.
Jan 31, 2010 | Watches
Lost manual to set atomic 4045 watch
Unfortunately no. You will need to try contacting Invicta direct. Sometimes you can go to Invicta retailers and they will have some left over or they will have instructions for similar models.
Mar 26, 2009 | Invicta Atomic Autotech 4051 Watch
How to set a invicta 3443 watch up
To set the time pull the crown out to the first position and set the time by turning the crown. Pull the crown out to the second position to set the date. Since this is a diver model you will need to unscrew the crown before it will pull out. Make sure you replace the crown and screw it back down for a good protective seal.
The alarm sets the same way. Unscrew the button to set.
Nov 24, 2008 | Invicta Pro Diver Collection Grand Diver...
Watches Logo
37 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
