Question about Goodman PHKJ048-1 Air Conditioner
Why my goodman model gsh130601ab out side fan does not come on
    Genius:
  • Goodman Master
  • 1,033 Answers
First verify if the outdoor unit is receiving voltage, if so could be a bad capacitor or the bearings in the motor have seized. Easy way to check is to spin the fan blade with a screwdriver, if this gets the motor going, the capacitor is bad, if not the motor is bad. If no voltage at outdoor unit, check breakers.
Posted on May 17, 2014
Have a 2 stage 70000btu 2 stage furnace by goodman. I have hooked up a honeywell steam humidifier. and when it calls for humidity the high fan speed does not kick in. The only fan speed that kicks in is...
Sorry to read about your problem, I hope this helps you out.
well its best to let the low fan do the humidity work, and not the high.. you did not provide the model of the goodman, but you ether went direct to the heater control card, to the humidity connection . or wired to the low side call contacts. you can hook the humidifier to the high fan speed contacts
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Goodman Heating & Cooling
Fan on outside unit spins counter clockwise pulling air in instead of forcefully blowing air out as it should. This fan doesnot look reversible, could this be the wrong fan or is there a way to reverse it?...
air should be coming out of the top. It will work either way. If your fan is reversible it will have a sticker on the side explaining how to reverse it and it will have exttra wires plugged into each other right at the motor. good luck
Jul 28, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a Goodman A/C unit model # GSC130361F A and a Evcon
The indoor fan should cycle with the outdoor part, make sure the thermostat is not set to fan "ON" and if the fan is on "AUTO" it could be a wiring issue or a fan relay that is stuck.
May 28, 2010 | Goodman CLQ36AR49 Air Conditioner
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Oct 22, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
67 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
