Question about Boating
What is wedge insert on a padde used for? - Boating
Unlock Chevy spark with slim Jim
Most lock out companies use a long metal rod that is inserted through the top of the door and is then used to push the power door lock button or the lock button. If you gently pull on the top of the door and insert a wedge to keep the door ajar slightly, you can use a coat hanger and manoevere it to touch the door lock button
Sep 05, 2015 | Cars & Trucks
Locked out of my 2000 chevy impala. slim jim nor keys work. how can i get in through the trunk
Did you call a locksmith,or call dealer and ask for parts and see if they know how.
Aug 01, 2015 | Cars & Trucks
Where do I find the code on my car
Factory Code was on a plastic card when new
To get that ,you need to give a dealer your Vin #
& proof of ownership.
I don't know if you can over ride your code with the
factory code
I have changed codes ,but not tried to enter the factory
one over mine
You vehicle comes with 2 keys & a valet key & you should have
a 3rd key bought & you program it.
What about the remote KeyFOB You should have 2 of those
to open the door
No reason to only have one key
Also the ignition is programmed for 2 keys or
it won't start
Nov 22, 2012 | 1999 Mercury Mountaineer
I locked my keys in my 04 tahoe
ok this is what you do to get in without AAA or a locksmith. find a long piece of metal bendable wire. (metal coat hanger) and make it striaght and make a hook on the end of it. Next find a wedge (door wedge works). put the wedge in the side of the door. where the front door meets the rear door. and push it in to slightly open the door. Its easiest to insert to wedge at the top side corner near the top of the window and slide the wedge down to near the door handle to make the opening wider. next (with the wedge stuck in the door crack) slide the long metal wire into the opening at the top of the door corner and either press the unlock switch or grab the door handle and open the car. good luck! hope this helps ya
May 04, 2011 | Chevrolet Tahoe Cars & Trucks
Radiator drain
If you replace radiator then it might or might not have an aliegn wedge thread insert but just remove
lower hose radiator cap when cold use towel to protect when openning cap.
Dr.Raymilyea
Feb 22, 2011 | 2003 Chevrolet Impala
My daughter just inserted the memory card the wrong way round in her brand new Canon A495. Now we cannot remove it. Help!
have you tried a small pair of needle nose pliers, or perhaps hemostats? if nothing else you can try and wedge it out with a butter knife or something thin like that. you could try 2, one from each side and try and wedge it out that way.
Dec 31, 2010 | Canon PowerShot A495 Digital Camera
Will not knead the dough paddle dosen't move--you can move by hand it is not stuck
If motor is still working ok, it is probably a bad belt inside the machine that turns the padde.
Dec 27, 2009 | Breadman TR2200C Ultimate Bread Maker
How do I get my trailblazer unlocked if my keys are locked in?
if its a newer model you might be able to call onstar, they will unlock via satelite, otherwise a wedge and a coathanger, insert wedge prying the door open above window and use a coathanger to hit the lock button
Dec 25, 2009 | 2002 Chevrolet TrailBlazer
Locked the keys in my truck
if you have electric door locks then you need a special break in tool if your not going to call a locksmith to open the door, get the plastic wedges to wedge door open wide enough to insert the push rod tool , they are plastic and will not scratch your paint if you use them carefully, you will have to push on the electric door lock button... or call a Lock Out tech, about 50 bucks if you don't have AAA...please rate help, thanks....
Aug 05, 2009 | 1998 Chevrolet C1500
Boating Logo
137 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
