Question about Sharp EL-2630P Calculator
I have a Sharp EL 2192C. How do I install the paper
3 Suggested Answers
SOURCE: new Sharp EL-1192BL electronic calculator
husband finally found the instruction guide!!
Posted on Mar 26, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
Paper does not advance properly on my sharp el-1801p calculator
probably there is paper underneath the printer..if you are handy you have to open the printer underneath to take stuck paper out.
or take apiece of clear place ,that can enter where you pass the paper.and let the plastic come the other side out.
probably it willcome with anything that is stuck beneath the printer
M.P
Sep 11, 2014 | Sharp EL-1801P Calculator
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    New Sharp EL-1192BL electronic calculator
    Mar 26, 2009 | Sharp EL-1192BL Calculator
    Tape wont register on this after we changed the tape
    Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
    1. Lift the paper holder up.
    2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
    3. Insert the paper roll from the left side of the paper holder and make sure the paper
    roll is set in the proper direction (with the paper feeding from the bottom).
    4. Insert the leading edge of the paper into the opening directly behind the print
    mechanism.
    5. Press the paper feed key and feed the paper under the edge of the paper cutter.
    Dec 07, 2007 | Sharp EL-2196BL Calculator
    Sharp EL-2196BL
    mechanism.
    Sharp EL-2630P Calculator Logo
    265 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
