Pro c900 sc477 - Office Equipment & Supplies
I am getting error code sc477 on my ricoh 901
SC477-00 Belt Centering Sensor Error
Belt centering sensor connector loose, broken, defective or
Belt centering sensor defective.
Also:
To ensure that the ITB Cleaning Blade always touches the ITB at the correct angle the lubricant was changed from powder to toner. If the blade is not at the correct angle SC477 may occur.
Apr 21, 2017 | Ricoh Office Equipment & Supplies
NordicTrack C900 Pro Won't turn on
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
Mar 06, 2015 | NordicTrack Exercise & Fitness
What are the Ricoh c900 power requirements
Hello there,
Well , from this Brochure here http://ricoh.co.in/products/brochures/Pro-C900S-C900.pdf
Power source:220-240 V 25 Amps ,single phase AC
•Power consumption
- Maximum:Less than 5.5 KW
- Energy saver mode Less than 3.2 KW
Sep 11, 2014 | Office Equipment & Supplies
Manual pdf
pleaso go to http://support.nordictrack.com/
and download PDF.
God bless you
Sep 28, 2013 | Nordic Track C900 Pro
Taking apart move
you must follow the steps indicated in your owner manual, please read carefully. or download free
www.fitness.manualsonline.com
God bless you
Jul 17, 2013 | Nordic Track C900 Pro
My New Nordictrack c900 pro turns on but does not run.
You probably pinched some wiring during assembly. Could be the controller but more likely the wiring.
Jan 03, 2018 | Nordic Track C900 Pro
How to replace catridge
Locate Empty Toner Cartridge
  • Turn off your Epson C900 printer and unplug it from your computer and from the electrical socket. Open the left-side panel of your C900 printer and locate the toner cartridge you want to replace. Epson has labeled each of the four cartridges.
Remove Old Toner Cartridge
  • Stick a finger in each of the holes in the empty toner cartridge. Pinch your fingers together and then slide the cartridge out from the printer's interior.
Insert New Toner Cartridge
  • Remove the new toner cartridge from its packaging and shake it vigorously to remix any settled toner. Take the cover off of the new cartridge by lifting it up and out to the right. Slide the new toner cartridge into the empty slot in your C900 printer. Close the left-side panel of your C900.
Oct 07, 2012 | Epson AcuLaser C900 Printer
What is the difference betwwen the hayward C900 and the C1200. I current have a C900 and the pool has a 1 1/2 hp pump I was thinking of and up grade
Most pumps are sized to the plumbing and filter size. If you go with a bigger pump and don't have the right size plumbing you can downgrade the water flow and create cavation noise in the system while actually getting less flow. If the filter is to small for the new pump you can get the same thing along with the bonus of hurting or cracking the filter. This is where you may want a pro on site (not Johnny One Truck) to help with this decision.
May 19, 2010 | Hayward 3/4hp Super Pump Inground Pool...
16 people viewed this question
k24674
jasbo
jasbo
