Question about Brother MFC 210C All-In-One InkJet Printer
How do I clean printer heads MFC 9460 CDN - Brother MFC 210C All-In-One InkJet Printer
Mix-it-up
  • 832 Answers
SOURCE: MFC 3240C printer head
ph cant be cleaned from outside. It cleans itself by printing with original ink which contains special fluids.
Posted on Apr 20, 2008
SOURCE: Brother mfc MFC-5440CN magenta issues
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
Posted on Jun 25, 2008
SpideRaY
  • 687 Answers
SOURCE: how can i clean my mfc 210c printer head maually
The majority of the printer parts like take up rollers and gears can be cleaned using Rubbing (IsopropylAlcohol or aka Surgical Spirit in the UK this will remove ost of the finger grease that can build up over time.
I wouldn't however suggest that you attempt to manually clean the print heads as they can easily be damaged and destroy the printer replacement heads can be as much as a new printer and difficult to change.
I recommend using the deep clean function found in the printer driver maintenance tab, you might have to run it 3 times at least if you don't use your printer very often.
Tip is to always leave enough ink in the cartridges to prevent the heads from drying out, this is why most manufactures tell you to replace ink when there is about 5% left in them to prevent this happening
Posted on Nov 04, 2009
SOURCE: Brother MFC 210C printer unable to clean print head
If your printer is like the 420CN Model, do not forget to disconnect the printer for resetting purposes and connect it again and it may clean properly and run fine. Good luck! hopes it work. It did for me. My printer is working fine and I like it. It does the work.
Posted on Aug 02, 2010
F Victor man
  • 821 Answers
SOURCE: I have tiny black dots
It sounds like the toner cartridge is spitting toner onto the drum. try another toner.
Posted on Jun 02, 2011
Clean brothers mfc240 print head
You need to follow these options for cleaning your printer.
1. open your case and remove the cartridge from your printer and clean your cartridge area.
2. now you need to clean paper rolloer area.
3. once you will do that then you need to clean your printer tray and other area.
How To Clean The Cartridge For Brother MFC 240C Printer
for more information please watch this video.
Feb 21, 2015 | Brother MFC Office Equipment & Supplies
How to clean printer head on brother MFC-J625DW
every brother has the ability to clean head, open control panel, open add printers, check your brother properties and click clean heads.
you also should have keypad access on brother to clean heads.
suggest you read the manual for proper code sine most Brothers have different codes.
Feb 07, 2015 | Brother MFC-J625DW Wireless All-in-One...
DRUM RESET 9460
While unit is ready state, press the 3 and 9 buttons together. The reset menu should appear on the display then scroll down to drum and follow directions on screen. This will also let you reset the fuser, laser and paper feed kits.
Jul 15, 2013 | Brother MFC-9460CDN Laser All-in-One...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
I have tiny black dots printing on all documents from my Brother MFC 9460. How can I fix this?
Jun 02, 2011 | Brother MFC9460CDN AllInOne Laser Printer
Clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - suvidha_times@yahoo.co.in
Jul 29, 2010 | Brother MFC-440CN InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
How can i clean my mfc 210c printer head maually
Nov 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
Print head for brother mfc420cn
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Hope that helps,
Take Care,
Michael
Nov 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Apr 17, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
113 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
