Question about Kodak ESP 5 Printer
Had to grt a new Hard Drive. I need a disk to install the printer
  • Kodak Master
  • 13,433 Answers
Please send me the brand and model of the printer with the add a comment link.
Posted on Jun 23, 2009
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
How to install New firm ware in new hard disk printer hp designjet T1100Ps
When you installed the new hard drive, was it purchased from HP as the hard drive for the T1100ps, or did you install a generic hard drive like for a laptop?
HP uses a special formatting on their hard drive with its own operating system with the latest firmware already installed (not windows o/s), so just installing new firmware will not work...the plotter must be on and in a ready state to receive the firmware update.
Sep 24, 2013 | HP Designjet T1100ps Printer
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
I could not samsung scx 3400 printer to my pc having 256 MB RAM
I suggest you install more RAM and do a hard disk maintenance before you install the printer driver.
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time. http://www.fixya.com/support/r3559146-hard_disk_maintenance
Mar 08, 2013 | Samsung SCX-3400 All-in-one Laser printer...
I recently bought a new hard drive to update the "tired out" model in my gateway model gt5674. i was told that i needed a SAS compatable motherboard to get this new hard drive installed. is there any...
Take the disk-drive back to the computer-store,
along with your computer, and exchange the new disk-drive for one that is compatible with your computer. Within 15 seconds of viewing the "inside" of your Gateway, they should be able to identify the correct model of disk-drive that will be compatible with your current motherboard.
Or, the more-expensive option: buy a PCI add-in card to add a 'SAS-compatible' interface (although I've never heard of such an interface!!!!) to your computer.
Jan 15, 2010 | Office Equipment & Supplies
Printer will not install
Hello. Thanks for choosing Fixya! Click on your start button and then on printers and faxes. Look and see what other printer drivers you already have installed. Delete any that you no longer need and THEN install your new disc. Regards, Joe
Nov 12, 2009 | Office Equipment & Supplies
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
CANON IR 5000i
Uh oh! You probably will need a new hard drive for your 5000. A new drive will have to be installed by a tech, then formatted and new system software installed. The E602 with the 000001 sub code indicates a hard disk drive failure.
Aug 15, 2008 | Canon imageRUNNER 5000 Copier
SEAGATE HARD DISK DRIVE PROBLEM...
I am venturing a guess, but it could possibly be your memory and not your hard drive.
Additionally, you can partition and format the 40Gb HD in a second PC using a third party utility such as Partition Magic which would also allow you to verify the integrity of the hard drive
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 01, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Kodak ESP 5 Printer Logo
16 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
