Question about Yaesu FT-897D Transceiver
How yaesu 897d main dial disconnect - Yaesu FT-897D Transceiver
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
If you are asking How do you remove the knob? Carefully remove the rubber ring from the outside of the knob. This is called the Sleeve in the Manual. You will then see one or 2 set screws inside the holes which must be loosened. The knob should then slide off.
73 from Wade/KJ4WS
Posted on Aug 17, 2014
Is there a secret button combination to hard reset Yaesu FT270?
So you used the power on MONI depress/ channel F4 method to reset the unit and it did not work?
Dec 12, 2015 | Yaesu Ft-270r 5 Watt Waterproof Vhf Two...
Refuses to power on
Have you checked the fuses? Yaesu typically means a fuse on the power lead and the ground wire.
Jun 04, 2015 | Yaesu FT-897D Transceiver
How do I program my yaesu ft 2700rh ham radio?
Do a Google search for Yaesu and you will probably find the manuals for all of their amateur radios. If it's not there then contact them at their main office in California. I've always found their service people there to be very cooperative.
May 17, 2015 | Yaesu Radio Communications
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Have a dell latitude 600 d will not boot up goes right into bios mode and no modes work right back to screen windows xp thanks
Quite simple.. I've had several D600's.
You're not going to like the answer--
You OS is borked, or your hard-drive is damaged.
I'll go with the bored OS, as my D600 has survived years... What you can TRY:
Reboot the system, press F8 constantly as it turns on.. I'm mean constantly..don't stop.
1000x is okay..
It'll go into a grey screen, asking you if you want to boot into various optiosn... select, "Last known good configuration".
See if that boots. If it doesn't, do it again..select "SAFE MODE"... and you'll need to go into the recovery screen to "Restore from a previous state".
If that fails... Insert CD...reinstall OS :-(
Hope it helps.
Oct 19, 2012 | Yaesu Fc-30 Tuner For Ft-897 Ft-897d...
How do i get the channels to change on vx10 radio selector does not seem to change them radio recently repaired by yaesu and user manual not much help
The dial is probably locked. Look for a little padlock symbol on the display. Check the user manual for Dial or keyboard lock. Generally on Yaesu radios you use the function key plus a keyboard key. If the keyboard is labeled, you should see something that looks like a padlock next to the correct function key.
Feb 11, 2010 | Vertex Yaesu Radio FTH2009, FTH7009...
Vertex VX 400 reprogramming.
Yes you need a firmware program for that. Do you have a local shop in your area?
Jan 05, 2010 | Vertex Radio Communications
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-897D Transceiver Logo
55 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
