Question about Epson Office Equipment & Supplies
How to fix scanner lid won't close?
One week ago worked fine. Now Epson scanner lid only closes with tremendous force and leaves a 2 inch gap.
Davroslives
  • 29 Answers
SOURCE: Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Posted on Sep 10, 2007
SOURCE: Transparency adaptor won't close
I have the model Epson expression 1600 which is similar. Remove the transparency adaptor from the scanner remove the six screws that hold the bottom glass and plastic half of the unit. I used a bit of silicon based grease on all the surfaces that slide in the hinge mechanism. Note the micro switch on the right side of the hinge. It has to be depressed when the lid closes or the scanner thinks the lid is open. Over time the hinge mechanism gets slightly bent and it wont trip the switch. My solution was to just tape the switch closed. You may come up with a more elegant solution but the switch is the problem. Reassemble and your scanner should work with transparencies without the error message
Posted on Dec 29, 2008
SOURCE: g1 always displaying a force close message
Try downloading Txtract from the G1 Market. It's listed under "tools". Use this application to save the text messages you've been hoarding to your SD card, then delete the text messages from your phone. Your G1 will work like new again!
Posted on Jan 01, 2009
SOURCE: Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Posted on Feb 01, 2009
SOURCE: Error Epson RX 595- Close the Scanner Unit
I just had the same problem. I figured that there must be a lever that gets pushed in when the lid closes and sure enough there's a square hole in the vent area (look in the area below the serial number) and in that is a small lever is that gets pushed down by the piece that's attached to the lid. For some reason, it's not pushing it down far enough or the lever has bent and it doesn't connect. My only solution (for now) was to jam a pencil into the lever to push it down all the way and sure enough, it worked. I'm sure there's a better, more permanent (and more attractive) way to repair this, but for now, it works and I need to print out 60 copies of an event program for tomorrow night! Good luck!
Posted on Feb 13, 2009
Watermark soft close seat lid not soft closing
check with your local plumber or the manufacturer .
Apr 10, 2018 | Lid Home
Epson Perfection V500 Photo scanner cover will not close
Check to see if the cover open switch is stuck or the is anything blocking the closing motion, rectify.
Aug 24, 2014 | Epson Perfection V500 Photo Scanner...
Unable to close cover of scanner. Hinges are locked fully open. No information on how to unlock hinges
The scanner's lid pulls upward a bit, and can sometimes get stuck that way -- in that case, the hinges won't bend. Try making sure the lid at the hinge end is flush against the bottom part of the scanner.
May 06, 2011 | Epson Perfection v600
Error message on attempt to scan: "Instruction at "0x673328c8" referenced memory at "0x21900668". The memory could not be "read"." need fix.
I must blush to say that I reviewed the error messages more closely and discovered that the solution was with an application, not the scanner. Thanks tremendously for your prompt attention.
Nov 17, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson 4490 scans with colour streaks/ digital interference
did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Sep 13, 2009 | Epson Perfection 4490 Film / Flatbed...
Espon 1400 prob. with vista close the cd/dvd guide. It is CLOSED!
I am having the same problem. I am on my 3rd printer from Epson in 2 weeks.
The solution may be to buy another brand, but I have more in Epson ink & paper than I have in the printer.
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Epson stylus CX3200
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Jan 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
116 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
