Question about Sharp R-520LW Microwave Oven
My Microwave start button won't start but I can hold in the open lever part way and it will work.
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave problems. (its "sharp" brand but im not sure of the model #)
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: The microwave oven start button does not work. If
You probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If it's not the switch or mount, you may need to adjust the door alignment.
If you still need help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and requote your symptoms, as you posted previously.
Posted on Dec 07, 2009
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Oven door on PanasoniPanasonic microwave Model NN-SD277 won't open when pressing open button
I just had that problem. It is the plastic workings. One of the plastic posts that holds the pivoting lever had to be epoxied. That plastic rejects crazy glue, don't waste your time. Just epoxy and as much as you think can fit under the electronics and the metal plate you will have to pull out.
My suggestion is take pictures of every step so that you can hook all the electrics back up. There are some testy switches that must be unsnapped too.
www.ianklepsch.ca
Oct 08, 2012 | Panasonic Microwave Ovens
Sharp carousel microwave R216 LS door latch has a problem. It won't open and feels like there is just a spring inside. I dont know if I can open it and fix it.
It's probably a broken door open lever or door open button.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Oct 18, 2011 | Sharp R-216 800 Watts Microwave Oven
The door won't pop open, you hear the click and you have to manually ply the door open
Since no model number was posted, I have to give a general answer.
It's likely that one of the door opening parts (most likely the door open button or lever) is broken.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're
Sep 26, 2011 | Viking VMOC205SS Microwave Oven
Push button foe a R-1870F Microwave. Somehow the button slid down in behind the conrols. How do you get it out. It look like some type of spring holds it in place.
You have a broken tab on your door open button (drawing ref. 3-2-4) or a broken door lever (ref # 4-25).
The button is normally held out by the spring.
You can find the entire service manual for the R1870/R1871 at our site here.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Mar 10, 2008 | Microwave Ovens
Stuck door
theat screwdriver available at any leading tools sales shop. check the door open liver and may be that lever damage..
Sep 28, 2007 | Danby DMW902 Microwave Oven
Sharp R-520LW Microwave Oven Logo
21 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
