Question about Plumbing
Waterridge kitchen faucet leaking from a hole in swivel stem
Faucet has a pullout hose and a swivel stem to move the faucet from one sink to the other. There is a little hole in the back of the stem that leaks when water is running. Don't know the reason for the hole but it is the place where water is coming from. No leaks when no water is running.
3 Suggested Answers
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
  • 11 Answers
call ROHL at 800.777.9762 and request a new Cartridge. They will ship it at no charge.
Posted on Dec 18, 2014
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
Just purchased a Ladylux faucet for my kitchen sink and want to know if there is any way to strengthen the water pressure (water stream). It is too weak for kitchen use. Please advise at your soonest as...
Do you have good water pressure in rest of house if not you may have to put a pressure booster system in. if you do there may be a water saver washer in the end of the hose on the faucet,you can disconnect the hose and if there is a washer with small holes in it you can take that out(you may have to put some type of hose washer back in the hose so it dosen't leak).
Jun 13, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a Koiler A112.181M or 157-076-ST kitchen faucet. On the back there is a small hole and it is leaking.. What can I do to stop the leak( A small drip) Thank You Jeff
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
Sep 08, 2010 | Kohler Model 10433: Fort® Single-control...
Kohler Coralais K 15160 The body has a machined hole in the back, about the diameter of a toothpick. It has begun to leak water when the faucet is turned on, however this occurs once in awhile.
The front of the handle has a plastic button which can be removed with your thumb nail or tooth pick. Once the button is removed use a 1/8 allen wrench to remove the handle. Remove the decretive sleeve to access the top of the valve. Tighten the valve stem nut and reassemble. It the problem persists you may need a new valve or rubber seal. The best thing about Kohler is they offer a lifetime no leak warranty. I personally will buy Kohler faucets and toilets because of the quality and warranty. Delta has some hi end products but the support and warranty policies will make you never want to service a Delta product again. So if the faucet still leaks just call 1-800-456-4537, and they will send you a new faucet or parts.
Jun 24, 2010 | Kohler K-15160-7 Coralais single-control...
The pullout spout leaks
pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Jun 28, 2009 | Kohler K-15160-7 Coralais single-control...
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
