SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
SOURCE: Panasonic DMR-EZ47V DVD Recorder /
Yes, you can connect an HD set-top box to the Panasonic recorder and record from it, but I will need to know the model number of the set-top box to be able to tell you exactly how to connect and how to record:
If your set-top box has a S-Video OUT port, you will be able to record both HD and SD (standard definition / non-HD) channels. If it does not have S-Video OUT, you will only be able to record SD channels. The Panasonic recorder only has S-Video and composite video IN sockets. S-Video will carry an HD signal, but composite will only carry an SD signal.
If you can let me know the model number, I can draw a connection diagram for you and let you know which settings to use on the player for recording.
Please reply to me with this information by clicking on "Add a Comment" below your question.
Thanks,
BElectric
