Question about La Crosse Technology Ws9004uitcpb/9005 Rain Gauge W
Problem with a ws9005u rain gauge
Can't get zeros to come up after reinstalling battery's
Scale wont zero
Try to remove the battery and reinstall it after 5 secunds.
Be sure that the battery is ok.
Apr 17, 2014 | Smooth trip ST-LS7004-B Digital Luggage...
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
Feb 08, 2012 | IBM ThinkPad T41 Notebook
The back-up battery of my ipaq 1940 shows zero in "system". so every time I need to remove the battery, all my installed application are gone and need to reinstall. Kindly help on how to remove...
You would have to backup your iPAQ probably through your computer instead of on the handheld. Otherwise there is no way to save your applications.
Mar 01, 2011 | HP iPAQ H1940 Pocket PC
A few weeks ago my 97 cherokee's check guage came on. Voltage dropped to zero and then eventually drained battery. I removed altenator and had it tested. It tested ok and I reinstalled. When I started it...
Hello, Yes it sounds as if it is a computer problem. There is no way to bypass it you will have to replace the engine computer. Good luck and feel free to ask anymore questions about this and I will do my best to answer them.
Jan 29, 2011 | 1997 Jeep Cherokee Country
NETBOOK WONT TURN ON WITH OR WITHOUT BEING PLUGGED IJ WHEN THE NETBOOK WAS PLUGGED IN AND CHARGING, THE BATTERY HAD 100%. STARTED TO USE THE NETBOOK AND THE BATTERY LEVEL WENT TO ZERO %. NOW EVEN WHEN...
  1. Remove the battery for 15 seconds, and make sure the contacts are clean and free from dirt, dust, etc.
  2. Reinstall the battery and try to turn the netbook on.
  3. If it still doesn't work, replace the defective battery.
Jan 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My speedo does not return to zero when I'm stopped, and reads way higher than the speed I'm traveling, the longer I ride it seems to get closer to zero but not all the way.. I can disconnect the battery...
Hi Outlawexcava, try cleaning your speed sensor located on top of the transmissions right side between the top cover and the chrome starter end cap on Twin Cams and on top of the engine case between the rear cylinder and the starter motor for Sportsters. Remove the the bolt that secures the sensor and pull it out of the transmission. Inspect sensor for obvious damage and repace if necessary. If sensor has no damage then wipe clean any obvious contamination like micro fiberous material with a clean rag and reinstall, torque bolt to 8 ft lbs. Please visit the website below for more information and good luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Sep 12, 2010 | Harley Davidson FLTR-FLTRI Road Glide...
Every button simply puts zeros on the screen.... tried removing the batteries and the back up battery
If it isn't flat-out broke, I'd try deleting all memory and reinstalling. Don't add third party programs and hook to ti connect device explorer just to see how it loads it there. Other option take it apart but, I only seen one person with success doing that, the rest destroyed it.
Jul 10, 2009 | Texas Instruments TI-89 Calculator
Trojan on HDD want to Zero out and reinstall OS
Just to make sure of a few things, you actually want to install windows 98 when you could install windows XP? and the other thing is that you do not need to acutally "Zero" the drive out -as in writing zeros to all sectors- formatting it will suffice to remove a virus.
Jun 07, 2009 | Gateway GT4022 PC Desktop
Logitech zero calibration reset method
Have you tried using the Logitech calibration uninstall tool that erasers all joystick calibration from windows.
Download and run the Logitech Clear calibration (LWS_CLRC.EXE).
The Clear calibration Utility was developed by Logitech to resolve calibration problems with Logitech digital gaming devices.
NOTE: This utility strips all calibration information in the Windows Registry for all gaming devices. This includes any non-Logitech gaming devices that have been installed.
You may also want to uninstall and reinstall the Joystick Software as well. In some cases, if the calibration issue is within a game, you could try uninstalling and reinstall the game.
Please refer to your game manufacturer for instructions on uninstalling or configuring the game.
Note:
This calibration tool specifically mentions the Wingman Joystick, However, it works for ALL Logitech and NON logitech Gaming Joysticks and Gamepads.
Jun 06, 2009 | Apple Logitech Freedom 2.4 Cordless...
Cant find a constant ground connection
Hello deslamer07,
First remove the primary fuse on the 12V power wire.
Run a temporary wire from the NEGATIVE terminal of the battery to where the amp is located. You do not need to make a permanent connection, just wrap the wire around the terminal enough to get a good connection. Use a multimeter set to the lowest OHMS scale and test between your proposed ground connection and the negative battery terminal. A good ground will indicate near "zero" (or very near zero). If you don't get a "zero" reading, try to find a screw or bolt going into the metal of the vehicle. Again, the meter will read "zero" when you have located a good ground. Reattach the amp ground terminal to the good ground, remove the temporary test wire, reinstall the primary fuse and test the amp. If it was just the ground, you've fixed it.
Hope this helps.
May 01, 2009 | Jensen LXA300 Car Audio Amplifier
La Crosse Technology Ws9004uitcpb/9005 Rain Gauge W Logo
47 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
