Question about Goodman CLQ36AR49 Air Conditioner
We live in SC, have a Goodman 4 ton split system w
We live in SC, large ranch style house on hill with small basement and the rest a crawl space. We have a Goodman 4 ton split system w propane gas furnace, 12 seer, bought 2003, 1 yr warranty on labor. The AC hasn't been cooling. The repairman came today. He said it needs a new reversing valve at $1000. Is this the likely cause?
1.Why would this part go bad? How much does the part cost? How hard is it to replace? Is this price reasonable?
2. The floor is not insulated, the vents to outside are not very good. Should we put plastic over the sandy floor of the crawl space? If so, is 6mil black or clear better with 4-5" overlap?
Thank you, Mrs. Howard
    Sergeant:
  • 340 Answers
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Posted on Jun 23, 2009
  • 3 Answers
Reversing valve is for a heat pump, you don't have a heat pump
040463610
How large a space are you hoping to cool? One room? One LARGE room? One SMALL room? One floor of a two-story house? A whole four-story house?
What's your climate like where you live? Very hot, dry, year-round? Cool most of the year but two weeks of hot during the summer? Just a little too warm in summer? Blazing hot all summer, including nighttime?
How's the insulation in the building you want to cool? Is it a plain steel building with no insulation? Is it a trailer? Is it a frame house with 4" walls and R13 fiberglass insulation? An old frame house with no insulation? An adobe building? A timberframe house with 8" of polyisocyanurate foam insulation?
All these are important to know when you select an air conditioner.
For most of the USA, assuming a frame house with 4" of fiberglass insulation, a 10,000BTU air conditioner will cool one large room or two small rooms pretty well, or a 5,000BTU AC will do one medium-sized room. Different places, and different house designs, and different types & amounts of insulation, will all have a profound effect on how much AC you need/want.
Jul 25, 2014 | Goodman Heating & Cooling
The blower starts before its warm and it blows cold air for about 30 sec when its shutting down .
When any unit 1st come's on, you'll always have some cold air that's in the ducts that will blow out before you get warm air. If your duct work is uninsulated in a cold basement or crawl space then it will be even more noticeable. When the unit is heating from the Heat Pump mode, it takes a little longer for the gases to get warm enough so you'll fell heat. When it gets cold enough for the unit to switch from heat pump to the gas or electric heat source, you'll get warm air faster. If you have gas heat, some Thermostats have an anticipator setting for the gas valve. If it's set wrong it will effect the on/off cycle of the gas valve.
All duct work in non heated and a/c spaces, including inside walls,above dropped ceilings, in attics and crawl spaces, must be sealed & taped at the seams and joints and then insulated and taped.
Most new construction has solved that problem with insulated duct board, flexible insulated supply's and special tape.
Dec 12, 2013 | Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14...
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
Sep 24, 2012 | Goodman Manufacturing Goodman R410A 13...
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
I HAVE A NEW AC 2.5 TON GOODMAN, MY HOUSE IS 1600 SF I HAVE 3 BEDROOMS AND TWO ARE CLOLED AND THE VENTS ARE CLOSED TOO, WITH EVERY THING OPEN THE HOUSE WILL ONLY GET TO ABOUT 80-81 % NEW HOUSE WITH LOTS...
Depending on everything working correctly with the system, the problem I see may be the size of the system. 2.5 tons is enough to condition around 1000 sq. ft. At 1600 sq. ft. Of living space, you will need a 3.5 to 4 ton system. Unless it was designed in a way that 2.5 tons would work which i doubt, there would be a problem with the charge of refrigerant or other under lying problems. First I would make sure your system is designed right for your house, check all filters and air flow from the vents. Then you go from there. Q good way to check the charge without equipment to do it, on a warm to hot day the outside copper lines should be sweating and warm to hot air coming from the fan on top of the condenser. It's not the accurate way to do it, but a good check anyways. Hope this helps and good luck!
May 25, 2011 | Goodman CLJ42AR49 Air Conditioner
What size ton a/c unit outside would be used on a 1500 s.q.foot ranch home.
Try to get 15 BTU's per square foot living space. 22,500 Btu, or go a little higher at 24,000 or 2 ton.
May 07, 2011 | Coleman Heating & Cooling
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
I have a Goodman GSC130361DE it is too small for a 2100sq ft home
Well you have a 3 ton system, it might be a tick small depending on windows and insulation in the house. Make sure you set it at one temp and leave it. Zoneing would also help.
Jul 17, 2010 | Goodman CLQ30AR32 Air Conditioner
I am looking for how many tons of cooling my goodman condensor provides
  • Here's the data you requested:
  • Goodman CKL42AR42 Split System Air Conditioner
  • Type: Split System
  • Cooling Capacity: 40000 BTU/hr (3.3 tons)
  • Energy Efficiency Rating: 9 EER
Mar 19, 2010 | Goodman CKL42AR42 Air Conditioner
Did it solve the problem
Basement or crawl space? If basement get or set existing dehumidifier between 40% humidity and adjust from there. If crawl space cover crawl space floor with 6 mil poly to trap moisture, if not covered.
Nov 11, 2009 | Electrical Supplies
Goodman CLQ36AR49 Air Conditioner Logo
387 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
