Question about Wahl 9877-500 Beard Trimmer
Wahl 9880L will not charge
Yes I have a Wahl Lithium Ion model #9880L work fine when i first got it,but now it will not charge at all. I don't get it.Can someone help?
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
rick_stokes_
  • 61 Answers
SOURCE: How to attach beard regulator on Wahl Groomsman
The attachment should hook over the teeth of the blades and then snap onto the back end.
Posted on Sep 27, 2009
My wahl lithium trimmer won't turn off. Think it got water inside of it. What do I need to do.
take the batteries out. if that wont work you may have to throw them away and start over.
Aug 16, 2014 | Wahl Li Pro Lithium Ion Clipper Cordless...
Battery will not hold charge on my wahl lithium ion trimmer. Model 9854L. Do I need to replace battery? If so, how do I do that? Have trimmer for about 3 years
The battery may only be supplied with the charging circuit attached, best check with your local Wahl service agent. Lithium batteries are not generally sold to the public as they are dangerous (explosive) if charged incorrectly.
Oct 11, 2013 | Wahl Health & Beauty
Change battery wahl 9918c
How to change the Battery in a beard trimmer - YouTube
? 3:38
https://www.youtube.com/watch?v=QlLqB9S5oaI
Oct 20, 2013 - Uploaded by Shake the Future
Do you have a beard trimmer/clippers that don't hold the charge? Time to change the battery and give your beard trimmer a second life. .... Wahl Trimmer All-In-One Lithium Ion Unboxing - TimmyTechTV - Duration: 6:32. by ...
Jul 28, 2012 | Wahl 9916-800 Groomsman Beard Trimmer
I have the wahl super taper with 1-4 attachments. is there an attachment lower than a number 1
Yes there is Wahl attachment is call a 1/2" Manny's Sharpening Have all the Wahl Attachments, Here is the our web page with the attachment 1/2". Wahl Attachment web page
Dec 08, 2010 | Wahl Super Taper Hair Clipper 2000 Hair...
I bought a WAHL 9854-600 Lithium Ion All In One Trimmer when I was in US a month ago. I charged it once when i was in US and then returned to India. Though the charge lasted for a long time, I am unable to...
The voltage in India is 22V. The unit you purchased in the US is for use with 120V. If you have plugged the unit into your 220V electric supply without a voltage converter to lower the voltage to 120V, you have damaged the charging cord and it will need to be replaced
Nov 23, 2010 | Wahl Health & Beauty
Jun 08, 2009 | Wahl 8550
Wahl 9877-500 Beard Trimmer Logo
57 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
