Question about Admiral Refrigerators
Admiral ltf2112ar The fan in the top freezer runs always. Is this normal, or should it shut off sometimes?
5 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Maytag Admiral LTF2112AR Fan inside of Freezer not
That will not be hard to diagnose or repair. Unplug refrigerator in not already. Then remove the rear panel in back of the freezer. Unplug the wires to fan and check voltage to the wires that were taken off the fan for 120 volts while someone plugs the power back in. If you have voltage in the 2 wires then see if maybe someone closed the refrigerator for a while and let rust set in on the fan bearings. Try spinning the fan before replacing. It could be stuck from setting up. If the fan is burned out replace the fan motor part number 63001057 Plug back in and you should be good to go. Sea Breeze
Posted on Nov 21, 2009
  • 2006 Answers
SOURCE: I have an Admiral top=freezer
Is the compressor making the noise or is it the fan motor that is making the noise. If the compressor then you are looking at over $500 for replacement and you will have to decide if your refrigerator is worth that type of investment.
But if it is the fan motor, then you could replace it yourself. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170333 Item 11 is the fan motor and you could replace it. The compresson is item 1 and would require a trained person to replace it.
Posted on Jun 16, 2011
heatman101
  • 43501 Answers
SOURCE: FREEZER NOT FREEZING, AIR IS
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 11, 2011
Macmarkus
  • 2605 Answers
Hello, welcome to FixYa.
I'd be glad to address your concern on a LTF2112AR Admiral refrigerator (these are built by Maytag as you may or may not know) that as you stated "AIR IS COOL BUT NOT ENOUGH TO FREEZE WATER OR MAKE ICE CUBES, FRIDGE NOT AS COLD AS IT SHOULD BE", correct ?
While I can't speak to the issue of the bugs, I should be able to assist you to a solution with the cooling issue. I suspect if the unit were cooling correctly the bugs would be gone.
You mentioned the fan in the freezer is indeed operating, air movement can be felt, correct ? This is important because it will indicate if the unit is stuck in defrost.
I apologize for all the question,s but I find it is the best manner in getting to the actual issue as opposed to trying 20 different things.
If you can slide the fridge out it will be necessary to acknowledge if the condensor fan by the compressor is operating as well as the compressor itself. There should be a cover at the back made of cardboard you will likely need to remove.
Knowing both or either one of these components status will go a long way to determine what the possible problem and solution will be.
**I also have a complete service manual for these Maytag built units if it may serve you better. If interested please reply with an email address and I'll send it to you as a "pdf" attachment**
I will watch for your reply and we can go from there based on what you find. If you can also disclose whether or not you have testing equipment such as a miltimeter or what tools you have to work with.
Regards,
Macmarkus :)
Posted on Sep 19, 2011
I have an admiral refrigerator admiral designer series 21.1 cu ft.the motor is constanly running 8 to9 hrs at a time the left side of the door is always hot and the top of the refrigerator a repairman came...
yes compressor runs and shuts off every 8 - 10 hours for a half hour for defrost system mode. but ur hot left side may be a sign of issues needing to be addressed>
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 26, 2015 | Admiral Refrigerators
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
Water is dripping down the back of the inside of the refrigerator. Maytag Admiral LTF2112AR
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Maytag Refrigerators
I have an Admiral top=freezer refrigerator model LTF2112AR. Suddenly, this evening, the motor in the back of the freezer began making continuous noises, it sounds like a grinding noise, but it is still...
Jun 16, 2011 | Maytag Admiral Top-Freezer Refrigerator
Maytag Admiral LTF2112AR Fan inside of Freezer not working
Nov 21, 2009 | Refrigerators
We have an Admiral top freezer refrigerator. Freezer is working refrigerator is running at 60 degrees.
If there is no ice on the back wall of the freezer, make sure the freezer fan motor is running. If there is ice on the back wall of the freezer repair the defrost components. Timer,heater,thermostat.
Jun 09, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Jan 31, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
