Question about Plumbing
Pacific Hydrostar auto home pressure booster pump 800 watt/model 96719 loosing pressure
Pump looses pressure when in use. what is wrong with it. where do we look for answers.
5 Suggested Answers
SOURCE: Winterizing a well pump and pressure tank
If this is the pump I am thinking of, it should drain if you disconnect the hose to the pressure tank.
The other option is to place a "T" connection on the intake to the pump, between the pump and well. Place a garden hose valve on the new branch. After you drain your system, attach a 2' hose to the new valve and place the other end into some antifreeze. Run the pump to draw some antifreeze into the unit. This will protect it from freezing and rust over the winter.
Posted on Apr 26, 2010
  • 4 Answers
SOURCE: Wher can I get a manual for a pacific hydrostar
http://manuals.harborfreight.com/manuals/2000-2999/2955.pdf
Posted on Jan 09, 2011
dogsled48195
  • 411 Answers
SOURCE: I have a pacific hydrostar vertical float sump
The Float Switch (2) automatically switches on and off at a water depth of approxi. mately 4 inches. The ON/OFF height can be manually changed by adjusting the Float Switch Lock.
Posted on Jan 28, 2011
Healeyman
  • 1198 Answers
SOURCE: hydrostar manual
If it doesn't have a pressure switch, install one.
Posted on Dec 01, 2013
Throttle linkage diagram for pacific hydrostar pressure washer 4 hp
For a throttle linkage diagram, contact Pacific Hydrostar directly.
Apr 21, 2017 | Garden
How much oil does a pacific hydrostar in the pump their is no site glass pump 95618
There is no oil in this pump. When storing it long term , put some automotive antifreeze in it. Disconnect the water hose and tip the unit on its face to drain water out of the inlet fitting for short term non freezing times.
Aug 22, 2016 | Garden
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
Hydrostar manual
they are sold @ Harbor Freight Tools, you can try there, the only other place that I can find this brand of pump is @ sears, but that is only for small 264GPM submersibles. can't seem to locate a web site for the company that makes them. you may look on the pump to see if you can locate where they are made.
Aug 18, 2014 | Plumbing
Hydrostar manual
Nov 30, 2013 | Plumbing
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Nov 20, 2009 | Garden
Plumbing Logo
65 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
