Question about Ingersoll Rand Compressors 5-HP, 80-Gallon, Triple Stage Rota
How to change oil on ssr ep25 compressor - Ingersoll Rand Compressors 5-HP, 80-Gallon, Triple Stage Rota
2 Suggested Answers
  • 205 Answers
SOURCE: I need to know what kind of oil to put in my SSR
I recommend ultra coolant by IR. This is a poly glycol base synthetic lubricant. Any poly glycol base lubricant will work. DO NOT mix different lubricants.
Posted on Nov 14, 2010
Why is oil being sprayed on the inside of the air filter ingersoll rand air compressor ssr-ep50se
you're oil separator has failed or the machine is not scavenging back to the compressor
Oct 17, 2014 | Air Tools & Compressors
What is the the solution for high airend temperature for Iraq ssr compressor.
low oil demmand or oilcooler dirty or thermostatic valve not opening or fan not coming on
Sep 27, 2014 | Air Tools & Compressors
Our company has ingersoll rand air compressor model SSR MM 150 is giving high temperature of air ultimately facing moisture problem at downstream of dryers.Need your assistance.Kindly send the manual if...
make sure the cooler is clean..change the oil filter if hasn't been changed in a while..could be bad thermo valve..oil level?How many hours on machine?
Nov 06, 2010 | Air Tools & Compressors
Hi, whats the oil capacity for an ingersoll rand compressor? serial: G9874V02140 model: SSR-EP50SE 215 CFM nominal drive motor 50HP we are about to make an oil change[thank you]
Below is the procedure for COOLANT change including amount needed.
SSR Ultra Coolant (Standard Factory Fill)
SSR Ultra Coolant is a polyglycol base coolant. Change
Ultra Coolant after every 8000 hours or every two years,
whichever comes first.
In addition to the tools normally found in any reasonably
equipped serviceman's toolbox, the following items
should be available at the work site:
1) Suitable drain pan and container to hold lubricant
drained from unit.
2) A quantity of proper lubricant sufficient to refill the
compressor.
3) A minimum of one replacement coolant filter element
of the proper type for the unit to be worked on.
There is a coolant drain valve on each compressor. It is
located on the bottom of the separator tank.
The coolant should be drained soon after the compressor
has been shut down. When the coolant is hot, the
drainage will be more complete and any particles in
suspension in the coolant will be carried out with the
coolant.
Hot coolant can cause severe injury. Use care when
draining separator tank.
To drain the unit, place drain pan under drain valve. Open
drain valve to start drainage. After draining is complete,
close drain valve.
After the unit is drained and a new coolant filter element
is installed, refill the system with fresh coolant through
the filler cap on the side of the separator tank. Bring the
receiver level of coolant up to the top of the sight glass.
Replace the fill cap. Start the compressor and allow it to
run unloaded for a short time. The correct coolant level is
at the midpoint of the sight glass with the unit running in
the "UNLOADED" mode. If the level is not near the
midpoint, stop the compressor and allow all pressure to
relieve from the system. Open the fill cap and add more
coolant.
50 hp (37 kw).....................3.4 gallons (12.9 liters)
Coolant fill quantity
! WARNING
Use care when near this area.
Use only recommended
coolant.
Read instruction book
before servicing.
39543921
run unloaded. The coolant level should now be near the
midpoint of the sightglass.
DO NOT OVERFILL THE MACHINE. Over filling will
affect separation and carryover down stream.
Sep 06, 2010 | Ingersoll Rand Compressors 5-HP,...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Compressor spits out oil when unit is stopped
MIGHT CAN HELP. NOT AN I.R. EXPERT BUT KNOW A GOOD BIT ABOUT SCREW COMP. ARE YOU SHUTTING UNIT DOWN SUDDENLY WITH EMERGENCY STOP OR SOMETHING. SOME UNITS DO THIS MORE THAN OTHERS BECAUSE THE WAY THE VALVE CLOSES. BURPING OIL THROUGH THE INTAKE IS ALSO CAUSED BY SUDDEN STOP INSTEAD OF THE UNIT SLOWLY SHUTTING DOWN AND THE OIL IS RUNNING BACK SLOWLY. THE UNIT ACTUALLY TURNS BACKWARDS A LITTLE BIT. YOUR OIL SHOULD NOT COST THAT MUCH. YOU CAN CONTACT ME FOR PARTS AND PRICING ON THE OIL. YOU CAN SAVE ALOT OF MONEY WITH AFTERMARKET SERVICE PARTS AND OIL -THEYRE JUST AS GOOD AS OEM.I WOULDNT USE 30W OIL ! YOUR POOR AIR DELIVERY MAY BE AFFECTED BY WORN PARTS DUE TO LUBRICATION. HOW OLD IS UNIT? MODEL # ? CONTACT ME JBRIDGERS@CA-EQUIP.COM FOR INFO & PRICING. ME AND 1 TECH WOULD PROBABLY COME DOWN AND FIX IT FOR YOU FOR AN ALL EXPENSE TRIP FOR FREE. WE ARE IN NC AND DONT GET OUT ENOUGH.
Jan 20, 2009 | Ingersoll Air Tools & Compressors
Ingersoll Rand Compressors  5-HP, 80-Gallon, Triple Stage Rota Logo
52 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
