Question about Canon BJC S300 InkJet Printer
I just installed new color & b/w cartridges in my canon s300 printer but the type is faded.
    President:
  • 2,306 Answers
You need a new printhead number QY6-0037-000. Runs around $30.00. I have tried all methods of cleaning and none help, but with a new printhead your printer will work like new again.
Posted on Jun 23, 2009
Canon MX882 won't print. I put in new ink cartridges, cleaned the print head, shut the printer off and turned it back on. Nothing worked. I'm about to throw it out and buy a new printer. Any suggestions...
Regarding your recent inquiry about the Canon MX882 poor print quality/lack of printing performance, it sounds like the semi-permanent PRINTHEAD* is either clogged (from dried ink), has an electrical connection issue or has reached END-OF-LIFE*. To help determine which is causing the error condition, please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
(Review all steps below prior to beginning - ensure nothing has been overlooked)
1. Go into the printer's maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color: 1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2. At the printer's control panel under the 'Maintenance' or 'Tools' menu, activate a 'CLEANING' or 'HEAD CLEANING' to prime the ink system. Then Run the Inkjet411 'Ink Recovery Test Print' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
3. Check your user's manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges 'park' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
4. The Ink Absorber, if applicable depending on print model, may also be full which could also cause printing related issues (typically an error code will be displayed when the ink absorber is full)...here is a customer/yahoo response on this particular issue: http://answers.yahoo.com/question/index?qid=20130523085451AAE1TqW
5. Refer to our print quality support page to ensure other variables are not causing the issue such as printer driver settings or operating system device conflict, etc: http://inkjet411.com/?page_id=1432
6. If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
7. Reinstall ink cartridges and retest.
8. If all ink cartridges are printing normally then the problem may the printer driver (i.e. file conversion issue); if one or more of the colors remain missing (...on internal test print) then we suggest you return to your retail refiller (i.e. Costco) and request to have the cyan/black (or more) ink cartridges weighed and checked. They should also ensure the smart chips are properly reset.
9. If the problem persists with full ink cartridges, then the PRINTHEAD* is likely clogged or electrically damaged - see below.
-Thank you
Inkjet411 Suggested PRINTHEAD Cleaning Procedures - ADVANCED RECOVERY RESOLUTIONS ONLY
1.Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
3rd party PRINTHEAD CLEANING solutions (for additional reference only):
http://www.youtube.com/watch?v=FL8QaFVwsEs (Canon)
http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon Printhead removal / water flush)
2.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
A replacement PRINTHEAD can normally be purchased from Canon.com (genuine part) or from Alibaba.com (aftermarket part).
PRINTHEAD TECHNICAL NOTES:
http://inkjet411.com/?page_id=2934
IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
Typically the printhead should not reach it's end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical 'head strikes' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon BCI-3e Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=UvnrAsG2DIk
Canon BCI-6 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=N1dQuuJQYuo
Canon PGI-5/CL-8 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=4SSnu4XhWG0
Canon 220/221 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=YvXiiKVNVf8
Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
Canon 250/251 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=JJHUtt8M6Vw
Please advise if the above suggestions do not help remedy the current issue. For any additional questions please contact us directly: Inkjet411help@gmail.com
If you ever need to purchase a new Canon ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (purchases available to USA residents only).
-Thank you
Feb 26, 2015 | Canon MX882 All-In-One InkJet Printer
Canon pixma mx882 won't print red
Regarding your Canon MX882 printer's poor print quality (lack of color printing performance from Canon 225 or 226 ink cartridges), it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached it's END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
1.Go into the printer's maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
2.At the printer's control panel under the 'Maintenance' or 'Tools' menu, activate a 'CLEANING' or 'HEAD CLEANING' to prime the ink system. Then Run the Inkjet411 'Ink Recovery Test Print' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
    3.Check your user's manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges 'park' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
    4.The Ink Absorber, if applicable depending on print model, may also be full which could also cause printing related issues (typically an error code will be displayed when the ink absorber is full)...here is a customer/yahoo response on this particular issue: http://answers.yahoo.com/question/index?qid=20130523085451AAE1TqW
    5.Refer to our print quality support page to ensure other variables are not causing the issue such as printer driver settings or operating system device conflict, etc: http://inkjet411.com/?page_id=1432
      6.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
      7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Epson Printhead Cleaning (Flush) Procedure: http://inkjet411.com/?page_id=2836
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
        http://www.youtube.com/watch?v=3kKULRjqaLg (Epson #1)
        http://www.youtube.com/watch?v=i78Tu3RVO3s (Epson #2)
        8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
        -Thank you
Apr 02, 2014 | Canon MX882 All-In-One InkJet Printer
My CP2025 colors are not balanced. It prints purple, red, orange and yellow. Green is faded and looks yellow. Cartridges are new and look fine.
there is software cd along with printer u need to setup the software. if u installed it go to the main menu & find cartridge level. see if green is low. there are also utility like clean cartridge. use it. also reseat the cartridge. if nothing is working use new cartridge.
Sep 03, 2011 | HP Laserjet Cp2025n Printer
Not Printing
clean the head and see what happen
Jun 12, 2009 | Canon BJC S300 InkJet Printer
I have recently installed new catridge,but the printer is doing faded printing
Check the use by date on the ink retail box (not the cartridges), the ink might be past its best used before date.
Also make sure that the ink cartridges are sited firmly, if they aren't sited properly then the ink wont flow properly.
Jun 05, 2009 | Canon BJC S300 InkJet Printer
Faded print
Could you send me the model of your printer?
This problem is usually due to the Ink Cartridges. you have to replace the old cratridge by the original company's cartridge.
Jun 11, 2008 | Canon BJC S300 InkJet Printer
Color fading
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Jan 18, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon s300
is there an detachable print head?
Jan 04, 2008 | Canon BJC S300 InkJet Printer
Canon BJC S300 InkJet Printer Logo
147 people viewed this question
old marine
old marine
