Question about Onkyo TX-NR818 7.2-Channel Network A/V Receiver
Am/fm step up for onkyo tx nr 818
Trying to choose the right freq for Tx, USA. OPTIONS ARE, .. 10hz/200khz or 9khz/ 50khz? Also, I'm going to add an amplified antenna for better reception bc I'm in between to large cities (eg Austin and San Antonio), not sure if this changes anything. Any help would be greatly appreciated.
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Posted on Sep 25, 2008
SOURCE: Onkyo T-4500 FM reception problem
I have the same tuner...yes the fm and am frequencies are different there than north america...check to see if you have the "worldwide" model...there is a small switch under a small hole underneath the tuner to select the region for where it is to be used. If its not the worldwide model then i think your outta luck.
Posted on Jun 01, 2010
  • 241 Answers
SOURCE: I have a new Onkyo TX-SR508 receiver. When
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Posted on Jul 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: What are the correct connections to connect a
Depends what you're trying to do with two amplifiers. Fill in the intent piece.
Posted on Apr 14, 2011
Onkyo tx nr656 showing. NR:LCRSLSRBLBR, Any idea. Not working at all.
Hello, I am sorry about your issue. The receiver may have detected a problem with a speaker or speaker wire. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
May 13, 2017 | Onkyo Audio Players & Recorders
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
I need help programming my baofeng 997s
To programme a repeater. VFO mode & curson on top line of display. Enter freq eg 147.250. Go menu button change settings like offset, tone. In menu delete channel required eg 000. In menu below that, choose mem channel now 000 & it saves receive freq.
Exit. press *SCN button so R appears on display. Save as 000 again but this time it stores TX freq. In other words, you save RX first, then exit.Add * so R appears in display second time round and save again TX freq. Go to channel mode and see it is in 000.
I might do a video to help people. Its the same process with UV5r and other Baofeng. Simplex you just save in one operation because TX is RX.
Aug 08, 2014 | Radio Communications
I owned an onkyo tx-nr 414 ,i bought it in al danah mall dammam last one and half year ago and one day the the "NO STORAGE" came to the front screen of the display.
Hello, I am sorry about your issue. Have you tried changing sources after you plug it in. It sounds like you are in USB. Please try bd/dvd or cbl/sat. Thank you. Onkyo USA
Jun 13, 2017 | Onkyo Audio Players & Recorders
ONKYO TX NR 709 OPERATES WITH 120V FOR US BUT I WANT TO USE ON 220 V AT EUROPE, HOW TO CONVERT?IS IT ANY MODIFICATION OR CONVERTION WHICH MIGHT BE CARRY OUT TO WIRING OR TO RECEIVER'S POWER SUPPLY?
If your Onkyo does not have a voltage button (usually on the backside close to the power supply) where you can shift in between the needed voltage (typically from 110 - 230 voltage) you need to purchase a Voltage converter.
You need one that is able to convert from 110 volt and up to 220 volt. (Step up)
Here is a site which can inspire you to choose the right Voltage converter :
http://www.110220volts.com/Power/Voltage+Converters.html
Regards
Sep 27, 2011 | Onkyo Audio Players & Recorders
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to onkyousa.com or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
Can I connect an ipod to Onkyo tx-ds595?
Aug 21, 2008 | Onkyo TX-DS595 Receiver
Fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
Mar 02, 2008 | Onkyo TX-SR800 Receiver
Onkyo TX-NR818 7.2-Channel Network A/V Receiver Logo
18 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
