Question about Refrigerators
LFFH21f7hwJ how much would it cost for a new one
LFFH21F7HWJ upright freezer got unplugged and now we can't get it back on
If everything is normal except it's not running I would suggest that someone check the start relay overload on the compressor
Appliance 911 Sea Breeze
Aug 03, 2016 | Freezers
The upright frigdiare freezer displays -10 degrees and runs continusly i couldnt set it to 0
Good Afternoon Friend,
I understand your Frigidaire freezer, model# LFFH21F7HWJ, is displaying -10 degrees and runs continuously. I also see that you were unable to set it to 0 degrees. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try the temperature to 0 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Cost repair screen
The cost of the display panel itself will come around 2/3rd of the total cost of a new TV. In short, you might have to spend about 80% of the total cost of a new TV, including cost of panel + Service charges.
Oct 06, 2013 | Vizio XVT323SV 32 in. LCD HDTV
Cost repair screen
Will cost around 2/3rd of the total cost of a new TV. It will better to buy a new one.
Jun 18, 2013 | Sanyo DP50747 50 in. Plasma TV
How much to replace a screen in a 50" plasma tv ?
Replacing the screen is almost sure to cost more than replacing the set.
Dec 20, 2012 | Televison & Video
NEED A NEW SCREEN
Please check the cost of a new screen before you decide to buy one as the cost might be about 70% of the cost of a new TV. Also you have to be very carefully to install again with no warranty. So consider to scrap for spares and invest in a new model with added advantages and warranty.
Sep 26, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
How Much does a repair for a acer laptops back screen cost and the second Question is how much does a brand new acer laptop cost
A new Acer Laptop Screen would cost from 94.00 to 177.00 depending on the model number and size of the LCD screen.
A new Acer Laptop would cost from 235.00 to 690.00 depending on the Model number and size of screen, hard drive, processor, etc.
Good luck..
Nov 11, 2010 | Computers & Internet
How much does it cost to replace a LG 32 inch Plasma TV screen?
It may prove to be costly unless you are able to get one to swap from a salvage, a possible board failure.
So check the cost of the new TV to the cost of a new screen and if this comes to more than 50% of cost I would advice not to proceed unless you have a warranty cover.
Oct 05, 2010 | LG Televison & Video
How much does a new cluch cost
$7,000.00 for a new clutch.
$6.95 per mile to maintain.
Jul 12, 2009 | 2004 Lamborghini Gallardo
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
