Question about Kitchen Appliances - Others
Scotsman NME maker - Kitchen Appliances - Others
3 Suggested Answers
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
imufo2
  • 3773 Answers
SOURCE: ICE MAKER WILL NOT POWER
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 08, 2011
I have a CSX45A1D Scotsman under the counter ice maker. Need manual for this unit. Thanks Dennis
Hi I think your model is the csw45 if it is then you can download the manual from http://www.scotsman-ice.com/docs/uploaded/sct/manual/Csw45m.pdf
Jul 29, 2011 | Scotsman CSW451D 15" Ice Maker with 26 lb....
Scotsman ice maker wiring diagram dce33pa
Service manual
I worked on one recently and wrote about it HERE
Below that is a list of ice machine links to service manuals.
Jun 30, 2011 | Scotsman DCE33PA1BC 15in Built-in...
What do i need to do to get the scotsman cm3 connected and ready to operate
http://www.scotsman-ice.com/?xhtml=xhtml/sct/us/en/homepage/default.html&xsl=homepage.xsl
start with this web site and click on Sales and Service. Look for you specific model manual and it will have all the install info. Hope this helps.
Jun 12, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Jun 19, 2009 | Scotsman DCE33PA1SC 15in Built-in...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
