SOURCE: Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
SOURCE: where is the waste toner receptacle located on the canon IR 3300i
Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
SOURCE: Where is the waste toner bottle located?
this machine IR 2000 doesnt have waste toner bottle,the waste toner goes to the drum,you must replace the drum.
SOURCE: I cannot find the location of the waste toner bottle.
On iR 2200, the waste toner container is located from left side of copier. To be precise, on left side are door with handle (wich is opend to reach paper in fixing assy or duplex), beneath this door ( left lower section from the door ) is small cover with one screw, when you remove it you will be able to see waste toner container. Its a plastic botlle, remove it clean it and dry it.
SOURCE: i must replace the waste toner bottle but cannot
Hi there!On the left side of the machine,look from the bottom left side up and you will see one screw,Only one!Loosen it and in there is a see trough bottle,empty it out and take a piece of cloth and clean the 2 small round circles at the top and put it back,But make sure the circles are clean!!!Switch on and off and there you go!! Good Luck!
