Question about Mint Automatic Floor Cleaner
Why is my mint floor cleaner keep going in a circle? Only one wheel is moving?
Why is there a red light
Is the red light blinking? Are there any beeps or tones? If so how many beeps?
Jul 07, 2014 | Mint Automatic Floor Cleaner
Hard to push
There may be a dial or something to set your unit to "floor" or low, and "High", all for the type of carpet or flooring you are vacuuming... change the setting to the middle or "floor"/ low.
On the other hand, here is a silly experience we may be sharing- sometime these units have wheels set so that, when the unit is "parked" or upright, wheels come down in the back, thus pushing the front down. You can turn it on, but the wheels won't go back into the unit until you move the handle from the upright position... My ex spent 15 minutes trying to get the vacuum to be normal- and all she had to do was just get the handle back at 2 or 4 o'clock position, and it worked fine...
if that's what you did- you aren't the only one! :-)
Good luck.
May 26, 2012 | Dyson DC33 Multi-Floor Upright Bagless...
Can you advise which setting should be used on different floors, ie hard floors and carpets, theres 2 different settings and I don't know which setting should be used on the different floors
Turn the machine on and look at the bottom. Turn to the two settings. The setting that stops the platten wheel from moving is for hard wood floors. If you cant tell, then setting 1 is most likely for carpets and 2 is for hard wood floors. Your machine is primarily a carpet vacuum cleaner, so 1 should be for carpets.
Feb 03, 2011 | Hoover Vacuums
Roomba keeps going around in circles
Dear Roomba Owner,
For solutions to your Roomba Vacuum Problems click on the following link @ http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/home.php?p_sid=gG54ERqj
jackiaria
01e9bc8.jpg This Will FixYa!
A Lot of iRobots' Home Vacuums Need a Software Upgrade!
Feb 19, 2009 | iRobot Roomba 530 Robotic Vacuum
Hight adjustor does not work...
I think we got this figured out . . . . the height adjustment doesn't work when the vacuum is UPRIGHT, but when you disengage and lower the handle the plastic that is blocking the wheels from receding will rotate and then it can receive the plastic on the "top" of the wheel assembly. Try it and I think you will find that it works. I thought it was the wheels that were keeping the vacuum from working well, but that's not the case. Still don't know why it's gone to heck in 9 months.
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
How to install front wheels on upright hoover vacuum cleaner
Please be sure to unplug the vacuum before doing this. Pull the sides from top cover on the floor portion (Where the light is) and it pops right off. After the cover is off, step on the lever to tilt the handle back like you are going to sweep. Lay the handle all the way down to the floor to raise the bottom of the vacuum somewhat so you can reach under it. You should be able to push up on the front wheel assembly, it should be very loose. If you look on the top of the vacuum where you removed the cover you should see a clip that moves when you push up on the wheels. Carefully squeeze the clip to push it past the opening and the front wheel assembly should drop down to make removal possible. This works on the Breath Easy model.
Jul 24, 2008 | Hoover Vacuums
Mint Automatic Floor Cleaner Logo
93 people viewed this question
Top Mint Vacuums Experts
JoeVacs
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
