Question about Earthquake 6015V Rear Tine Rototiller
Cc to horsepower chart
196cc would be close to how many horsepower
What is. The wire coming out of the block of my 196 cc water pump engine
Hi, Dennis probably your thermostat temperature sensor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 06, 2017 | Loncin Motorcycles
How many horsepower is 452 cc
Nobody knows, because not even engines from the same make can produce a different power output. When you have different motors all with 452 cc, the output power can differ a factor 10.
There is no resemblance between horsepower and CC. You can calculate HP to Watt, and vice versa.
Mar 07, 2015 | Cars & Trucks
How many cc is equival in horsepower
You can't.
There is no formula to convert Cubic Centimeters to Horsepower. It doesn't work that way.
Apples and Oranges.
CC's are a unit of volume and horsepower is a calculation of work load. Only a dyno would be able to tell how much horsepower a given displacement will/would make.
You could have 2 identical CC engines and have totally different HP outputs.
Feb 15, 2015 | Garden
How do I convert 306 cc,s to horsepower
You can't. There is no formula to convert Cubic Centimeters to Horsepower. It doesn't work that way. It is like comparing Apples and Oranges.
CC's are a unit of volume and horsepower is a calculation of work load. You could have 2 identical CC engines and have totally different HP outputs.
Now if your had the engine's torque values like 6.5 FT LB @ 3050 rpm then you can convent that.
Feb 02, 2015 | Miscellaneous
Is there a conversion chart to cc to horsepower?
No. Cubic centimeter (cc) is a unit of volume. Horsepower is a unit of power. Two different 250 cc engines, for example, may put out different amounts of power, while 250 cc of sand won't put out very much.
Oct 22, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Calculate horsepower to cc
There is no direct conversion. cc is a measure of volume while horsepower is a measure of power. A 420cc engine may have enough power to drive a car down a freeway, but a 420cc pile of bricks won't.
Mar 04, 2014 | Office Equipment & Supplies
How many horsepower is 251 CC.
Horsepower is a measure of power. cc is cubic centimeters, a measure of volume. There is no conversion between them, just as there is no conversion between inches and pounds.
Now, if you were to ask how many horsepower a particular 251cc motorcycle engine produces...
Jan 04, 2011 | Office Equipment & Supplies
357cc is equal to what in horsepower MTD
From my website: movingsnow.com. Five years ago the power output of every snowblower sold here in the United States was measured in hp or horsepower. It was a nice simple measurement that everyone was used to.
Three years ago they changed the rules and started selling snowthrowers with the power measured in gross torque. Of course no one understood what this meant and even though companies like Briggs & Stratton tried to explain it, it still didn't make much sense.
Well they changed the rules on us again.
So we just start to get used to measuring an engine's output in torque and now for the 2009/2010 season a lot of the snow blower manufacturers are dropping the torque measurement and only giving us engine size in cc's.
I spent a great deal of time researching this and I'm not going to spend time trying to explain why the engine manufactures have changed their terminology. Instead I'm just going to show you a formula you can use to figure it out yourself.
Here's the formula I used from the Briggs & Stratton website (rpm x torque / 5,252) The engine manufacturer's used 3600 rpm most of the time to rate the engine's horsepower so I will use that number in the formula. I also used the torque ratings from the Briggs & Stratton website for their motors to keep this chart simple. Other manufactures (like Powermore) may have different torque ratings for their motors. If you are trying to get exact hp measurements you should research the torque ratings for the specific brand.
For 2009/2010 MTD has dropped all torque ratings on snow throwers. The engines are only labeled in cc's.
Here is a simple chart of approximate cc to torque to horsepower conversions. It's not exact, but it will give you a better idea of how big the new engines are. I used 3600 rpm in the formula for this comparison. Assume that your new snowblower motoe runs at less rpm.
123 cc = 4 hp
179 cc = 5 hp
208 cc = 8 to 9 Gross Torque = 5.5 to 6 hp
277 cc = 11 to 11.5 Gross Torque = 7 to 8 hp
305 cc = 13.5 to 14.5 Gross Torque = 9 to 10 hp
342 cc = 15.5 to 16.5 Gross Torque = 11 to 12 hp
357 cc = 12-14?
420 cc = 14-15?
To me cc's is not a good comparison from one motor to another. It is also not a good comparison from one manufacture to another. For example, a 190cc Briggs & Stratton side valve motor will not have the same power as a Honda 190cc overhead valve motor. cc'c doesn't give you a good measurement of what the engine is capable of. True, an overhead valve motor from a specific manufacture should have more power with more cc's but there are a lot of other factors that go into determining how much power is available for you to use. The true power of a motor is determined by engine type, (overhead valve/side valve) carburetor (naturally aspirated/fuel injected/turbo) rpm you use it at (2750/3100/3650) and many other factors. I hope this helps.
Jan 03, 2011 | Garden
Horsepower
Go to www.gmanindustries.com and look at the Bully FI controllers. There you will find dyno charts on the C90. It's right around 56-58 hp.
Nov 10, 2008 | 2005 Suzuki Boulevard C90
Horsepower
28.16 HP (20.6 kW))
Nov 10, 2008 | 2004 Suzuki 250 SB
Earthquake 6015V Rear Tine Rototiller Logo
Top Earthquake Garden Experts
Mike Forrest
Mike Forrest
Level 1 Expert
cwradio73
Are you an Earthquake Garden Expert? Answer questions, earn points and help others
