Question about Crafts & Hobbies
How to remove krazy glue from fingers - Crafts & Hobbies
I bought a glue the day before yesterday, and then opened it. Today, it solidified, there are a lot of glue, is there any way to make the glue did not solidified?
Krazy glue (aka super glue, cyanoacrylate) reacts chemcially with moisture in the air that makes it harden quickly (via a process of polymerization). The reaction cannot be reversed. These glues have a limited shelf life even if they are never opened as they will polymerize over time even without being exposed to air.
You can use acetone (nail polish remover) to loosen or dissolve glue that has set up but it doesn't restore it to a state where you could use it to again.
There's a reason this stuff comes in tiny tubes instead of large bulk containers.
Dec 08, 2017 | Cars & Trucks
How do I remove krazy glue on finger tips?
Use an acetone-based nail-polish remover.
Sep 20, 2014 | Cars & Trucks
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
How do I remove krazy glue from fabric
Try, Put a small amount of water over and around area, after put in the freezer, until the water on the dress as frozen.
Then delicatly scrape it off with a small exacto or small knife.
Sep 11, 2014 | Elmer's Instant Krazy Glue
How to unstick superglue
Try an acetone-based nail-polish remover.
Sep 05, 2014 | Elmer's Instant Krazy Glue
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
My floorpiece keeps turning on and off when I try and vacuum. It almost seems like it is shorting out, but it isn't. I suspect it is something to do with the handle piece attaching to the floor piece.
You are exactly correct.
What it is exactly is the hose connection to the power nozzle. The plug on the handle of the hose should be flush with the plastic piece below it. To correct this, you can open the handle and push the plug back into place. What I normally recommend is a super glue of somesort, like krazy glue.
remove the plug, glue into place and make sure that the recepticle or plug is out far enough to make a solid connection.
Good luck
Nov 04, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Interior windows frost up between 32 degess and lower. Fan on full and temp hi, takes forever to clear and noisy. 2002 xtype jag
you have alot of moist air in the car check to make sure your heater core doesnt have a small leak in it. also if the heater is noisy when on the bearing in the blower motor may be going bad replace it before you cant see out your windows at all
Dec 25, 2009 | 2002 Jaguar X-Type
MAC "WIRELESS MOUSE" A 1015. The cover fell off and the metal bar on the cover will not stay in place and the small plastic cover over the light will not stay in place. help
I used Krazy glue (ethyl cyanoacrylate). The metal spring bar was originally held to the the cover by a piece of plastic sticking through the larger round hole at the latch end of the metal bar. Put the glue at that spot only.
Oct 27, 2009 | Apple Bluetooth Wireless Mouse m9269zm/a
Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
